StarTech.com Gb Fiber SFP - Cisco Compatible
Quicklinx: C191WS00 Mfr#: GLCLHSMDST
Type: Modules
£39.15 ex VAT
£46.98 inc VAT
Add reliable, cost-efficient Gigabit Ethernet connections over single-mode/multi-mode fiber with this Mini-GBIC module. This StarTech.com Gigabit fiber SFP is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Cisco switches and routers that support the GLC-LH-SMD transceiver module, as well as other major brands of networking equipment.
It provides a dependable and cost-effective way to add, replace or upgrade the ports on your 1000Base-LX/LH networking equipment, and it's backed by a lifetime warranty.
This single-mode/multimode SFP transceiver is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The SM/MM Gigabit SFP is engineered to the highest quality standards and is 100% Cisco compatible, equivalent to the Cisco GLC-LH-SMD SFP transceiver. The StarTech.com SFP transceiver is configured and fully tested to ensure it works seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in switches, routers and other networking equipment, the SFP provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SFP supports Digital Diagnostics Monitoring and both single-mode (with maximum distance of 10 km or 6.2 mi.) and multimode (with a maximum distance of 550 m or 1804 ft.). It provides maximum data rates of up to 1.25Gbps.
You can count on GLCLHSMDST for reliable performance.
  • Versatile connectivity options
    This SFP module features LC connectors with two ports, ensuring compatibility and ease of use in various networking settings.
  • Reliable temperature range
    Operates efficiently from 0°C to 70°C, making it suitable for diverse operating environments.
  • Compliance with standards
    Meets various compliance standards such as UL, FCC, RoHS, and MSA, providing peace of mind regarding safety and quality.
  • Enhanced data link performance
    Utilizes Gigabit Ethernet protocol compliant with IEEE 802.3z, contributing to stable network performance.
  • Advanced features for functionality
    Includes features such as full duplex mode and auto MDI/MDI-X for optimized connectivity and performance.
StarTech.com Cisco GLC-LH-SMD Compatible SFP Module, 1000BASE-LX/LH, 1GbE Single Mode (SMF) Fiber Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 10km, 1310nm, DDM, Firepower - Lifetime Warranty (GLCLHSMDST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC
Plug-in module
Cabling Type
1000Base-LX, 1000Base-LH
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
Cisco GLC-LH-SMD
0.9 cm x 6.5 cm x 1.4 cm
25 g
P/N: IES101G2SFPW, IES101GP2SFW
Plug-in module
Silver
Wired
Cabling Type
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
10 km
Auto-uplink (auto MDI/MDI-X), full duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
IEEE 802.3z
1 x Ethernet 1000Base-LX/1000Base-LH - LC female x 2
UL, FCC, RoHS, MSA
Cisco GLC-LH-SMD
0.9 cm
6.5 cm
1.4 cm
25 g
Limited warranty - lifetime
70 °C
C191 StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £15.20
C191 StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £24.58
C191 StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £17.33
C191 StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £20.00
C191 StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £17.35
C191 StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £25.06
C191 StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) In Stock £25.08
C191 StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £22.20
C191 StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £24.64
C191 StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £17.85
C191 StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £19.85
C191 StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £146.68
C191 StarTech.com Fiber Media Converter - Open In Stock £44.55
C191 StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £232.51
C191 StarTech.com Gb Fiber SFP - Cisco Compatible In Stock £39.15
C191 StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £235.02
C191 StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £338.20
Type: Modules
