StarTech.com Flat-Screen TV Wall Mount
Quicklinx: CR96WS00 Mfr#: FLATPNLWALL
Type: Mounting kit
Hurry, only 3 left in stock!
£61.61 ex VAT
£73.93 inc VAT
Save space by mounting a flat-panel television to your wall, with easy tilt for ideal viewing. Maximize space while creating an impressive display with this heavy-duty wall mount for large flat-screen TVs or monitors. The flat-panel wall mount securely supports a VESA Mount compliant TV from 32" to 70", with easy-to-use tilt adjustment for comfortable viewing.
Mount your flat-screen TV in a location that's convenient for visitors, clients and employees, while saving valuable space. The wall mount is ideal for boardrooms, lobbies or other venues providing an impressive and secure way to display a large flat-panel TV or create digital signage. The robust wall mount supports a large 32" to 70" flat-screen TV weighing up to 165 lb. (75 kg).
The TV wall mount lets you angle your TV display toward your audience. With the tilt feature, you can mount your TV lower or higher than eye level and still view it comfortably. The tilt-adjusting knobs make it easy to adjust your TV to the ideal viewing angle.
The hook-and-mount design of the TV wall mount makes setup fast and easy. You simply attach the vertical brackets, with built-in hooks, to the back of your TV. Once the brackets are attached, you then hang your TV securely onto the wall mount. Cable management helps to keep cables out of view.
  • Ideal for the Boardroom, or Digital Signage
    Mount your flat-screen TV in a location that's convenient for visitors, clients and employees, while saving valuable space. The wall mount is ideal for boardrooms, lobbies or other venues providing an impressive and secure way to display a large flat-panel TV or create digital signage. The robust wall mount supports a large 32" to 75" flat-screen TV weighing up to 165 lb. (75 kg).
  • Tilt Your Display to the Ideal Viewing Angle
StarTech.com Flat Screen TV Wall Mount - Tilting - Supports 32" to 75" TVs - Steel - VESA TV Mount - Monitor Wall Mount (FLATPNLWALL) mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
Wall plate, 2 mounting brackets
81 cm x 8.3 cm x 50 cm
Tilt
-15° to 15°
Adjustments
Tilt
3.8 kg
Recommended Use
Flat panel
Recommended Display Size
32"-75"
VESA Mounting Interface
200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm, 700 x 400 mm
Max Load Weight
75 kg
Material
Steel
Package Content
Allen key, 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x washers, 6 x flat washers, 6 x concrete anchors, 6 x 6.3x55 mm screws, 8 x spacers (long), 8 x spacers (short), 4 x M8x50 screws
P/N: HDMIPLATE
81 cm
8.3 cm
50 cm
3.8 kg
Material
Steel
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
32"-75"
Tilt
-15° to 15°
Adjustments
Tilt
Max Load Weight
75 kg
P/N: HDMIPLATE
CR96 StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter In Stock £37.09
CR96 StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable In Stock £5.23
CR96 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.55
CR96 StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £78.49
CR96 StarTech.com Full Motion TV Wall Mount In Stock £268.32
CR96 StarTech.com VESA TV Wall Mount Full Motion In Stock £104.42
Type: Mounting kit
