Reliable connectivity
The media converter provides a stable connection between fiber and Ethernet networks, with a maximum transfer distance of 10 km. -
Robust design
Constructed with a metal housing, this converter withstands various environmental conditions while maintaining performance. -
Versatile compatibility
This device is compliant with multiple standards such as IEEE 802.3z and IEEE 802.3ab, ensuring it works with a wide array of devices. -
Efficient power usage
Using only 2.5 W during operation, this powered device ensures low energy consumption while providing functionality. -
User-friendly installation
The Plug-and-Play feature allows for easy setup, enabling users to quickly connect without needing extensive technical knowledge.
- StarTech.com Gigabit Fiber to RJ45 Ethernet Media Converter, Micro Mini - fibre media converter - 1GbE - TAA Compliant
- Fibre media converter - RJ-45 / LC single-mode / LC multi-mode
- Form Factor
- External
- Cabling Type
- 1000Base-T, 1000Base-LX
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 10 km
- 8.24 cm x 2 cm x 1.75 cm
- 49 g
- TAA Compliant
- 2-year warranty
- Form Factor
- External
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1GbE
- 1 Gbps
- 1310 nm
- 10 km
- Status Indicators
- Power, link/activity, fibre
- USB powered, metal housing, auto-negotiation, auto-uplink (auto MDI/MDI-X), Link Fault Pass-Through (LFPT) support, latching, EMI protection, unmanaged, Marvell 88E1512 chipset
- IEEE 802.3ab, IEEE 802.3z, USB 1.1
- 1 x Ethernet 1000Base-T - RJ-45 male , 1 x Ethernet 1000Base-LX - LC single-mode / LC multi-mode female x 2 , 1 x USB - Type A male
- Cables Included
- USB cable - 30 cm
- Plug and Play, IP20, WEEE, Laser Class 1
- TAA Compliant
- 2.5 Watt
- 8.24 cm
- 2 cm
- 1.75 cm
- 49 g
- Shipping Width
- 13.6 cm
- Shipping Depth
- 8 cm
- Shipping Height
- 3.2 cm
- Shipping Weight
- 80 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 85% RH
StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £15.24 |
StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £24.58 |
StarTech.com 15m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £30.58 |
