StarTech.com Fiber Media Converter - w/ SFP
Quicklinx: BM0PWS00 Mfr#: MCM1110MMLC
More than 50 in stock
£88.19 ex VAT
£105.82 inc VAT
Convert and extend different networks over a Gigabit fiber cable connection up to 550m / 1804 ft.. This fiber media converter offers an easy, cost-effective way to extend your network over Gigabit fiber. It is equipped with a multi-mode transceiver which converts a copper RJ45 Ethernet connection to Gigabit fiber to extend your network over longer distances or connect workstations to switches. The converter provides a powerful extended networking solution for campuses, businesses, government facilities, stadiums, or other areas requiring network access.
The Gigabit Fiber Media Converter provides a cost-effective and dependable solution for shorter range network extensions. It connects an Ethernet network to remote devices over a fiber backbone, with a 550m range on the fiber optic interface. The media converter has a durable metal housing, engineered to deliver long-lasting performance.
Fully compatible with 10/100/1000Base-T Ethernet networks, the fiber media converter supports auto negotiation to bridge different speed networks and devices to a Gigabit fiber network. It provides versatile connectivity to your existing networks and devices, allowing you to maximize the usage and performance of legacy equipment.
The multi-mode transceiver is removable, giving you the flexibility to change your transceiver in the future to meet your networking needs.
The unmanaged fiber media converter has a standalone design with simple plug-and-play set-up to ensure fast and easy installation. Compact in size, the converter gives you flexible installation options - including a wall mounting option to save space.
StarTech.com Multimode (MM) LC Fiber Media Converter for 10/100/1000 Network - 550m - Gigabit Ethernet - 850nm - with SFP Transceiver (MCM1110MMLC) - fibre media converter - 10Mb LAN, 100Mb LAN, GigE
Fibre media converter - RJ-45 / LC multi-mode
External
Cabling Type
10Base-T, 1000Base-LX, 1000Base-SX, 100Base-TX, 1000Base-T
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
Max Transfer Distance
550 m
AC 120/230 V
7 cm x 2.6 cm x 9.7 cm
200 g
P/N: SVA5N3NEUA
External
Brown
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Auto-negotiation, auto-uplink (auto MDI/MDI-X), Link Fault Pass Through function (LFP), Jumbo Frames support, metal housing
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab
1 x Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - LC multi-mode female x 2
MTBF
50,000 hours
FCC, RoHS, MSA
External power adapter
AC 120/230 V
5 Watt
7 cm
2.6 cm
9.7 cm
200 g
50 °C
5 - 95% (non-condensing)
P/N: SVA5N3NEUA
BM0P StarTech.com 1000 Mbps Gigabit Single Mode Fiber Media Converter LC 40 km In Stock £281.17
BM0P StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m In Stock £129.09
BM0P StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - ST In Stock £11.05
BM0P StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - ST In Stock £18.85
BM0P StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - ST In Stock £6.21
BM0P StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - ST In Stock £14.51
BM0P StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot In Stock £100.65
BM0P StarTech.com OAM Managed Gigabit Ethernet Fiber Media Converter - MM LC 550m - 802.3ah Compliant In Stock £154.97
BM0P StarTech.com Fiber Media Converter - Open In Stock £59.15
BM0P StarTech.com Fiber Media Converter - w/ SFP In Stock £88.19
Price Range Ex VAT: 50 - 100
