Product
StarTech.com Fiber Media Converter - Open
Quicklinx: BM0BWS00 Mfr#: MCM1110SFP
22 in stock
£58.43 ex VAT
£70.11 inc VAT
Standard delivery Delivered within 3-5 working days
Convert and extend different networks over a Gigabit fiber cable connection using the SFP of your choice. This fiber media converter offers an easy, cost-effective way to extend your network over fiber, using the SFP of your choice. It converts a copper RJ45 Ethernet connection to Gigabit fiber to extend your network over longer distances or connect workstations to switches. The converter provides a powerful networking solution for campuses, businesses, government facilities, stadiums, or other areas requiring network access.
The Gigabit fiber media converter provides a cost-efficient way to connect your Ethernet network to remote devices over a fiber backbone. It features an open SFP slot that lets you choose the MSA-Compliant Gigabit SFP that best suits your fiber connection mode (single / multi-mode) and distance requirements.
Fully compatible with 10/100/1000Base-T Ethernet networks, the fiber media converter supports auto negotiation to bridge different speed networks and devices to a Gigabit fiber network. It provides versatile connectivity to your existing networks and devices, allowing you to maximize the usage and performance of legacy equipment.
The unmanaged fiber media converter has a standalone design with simple plug-and-play set-up to ensure fast and easy installation. Compact in size, the converter gives you flexible installation options - including a wall mounting option.
StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot - fibre media converter - 10Mb LAN, 100Mb LAN, GigE
Fibre media converter - RJ-45 / SFP (mini-GBIC)
External
Cabling Type
10Base-T, 1000Base-LX, 1000Base-SX, 100Base-TX, 1000Base-T
Data Transfer Rate
1 Gbps
AC 120/230 V
7 cm x 2.6 cm x 9.7 cm
200 g
2 years warranty
External
Brown
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Power, link/activity
Auto-uplink (auto MDI/MDI-X), full duplex mode, Link Fault Pass Through function (LFP), Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab
1 x Ethernet 1000Base-T - RJ-45 , 1 x Ethernet 1000 - SFP
MTBF
50,000 hours
FCC, RoHS, MSA
External power adapter
AC 120/230 V
5 Watt
7 cm
2.6 cm
9.7 cm
200 g
50 °C
5 - 95% (non-condensing)
BM0B StarTech.com Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module - Mini-GBIC In Stock £55.19
BM0B StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £71.70
BM0B StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £42.04
BM0B StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) In Stock £39.96
BM0B StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC – 10 km (Mini-GBIC) In Stock £51.23
Price Range Ex VAT: 50 - 100
