Your basket is empty
StarTech.com Fiber Ethernet Media Converter
Quicklinx: 6BDCWS00 Mfr#: MCM110SC2PGB
This 10/100Base to 100Base-FX Multimode SC Fiber Ethernet Media Converter supports a maximum fiber cable distance of 2km, ensuring a highly reliable signal for ideal network connectivity and performance.
The converter features Power over Ethernet support that allows the converter to draw power from a PoE network, delivering the freedom to use the converter in environments and scenarios where additional standard power options are unavailable.
Rather than paying for expensive installations of power wire (at drop points that may have them), running PoE requires only standard network cable (e.g. Cat5e cable), eliminating cost and hassle.
The 10/100Base to 100Base-FX Multimode Fiber Ethernet Media converter features a durable design to help ensure reliability and long-lasting performance.
StarTech.com 10/100 Fiber to Ethernet Media Converter SC w/ PoE - fibre media converter - 10Mb LAN, 100Mb LAN
Fibre media converter - RJ-45 / SC multi-mode
External
United Kingdom
Cabling Type
10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
10Mb LAN, 100Mb LAN
Max Transfer Distance
2 km
Power Over Ethernet (PoE)
PoE
AC 120/230 V
7.3 cm x 10.8 cm x 2.3 cm
170 g
2 years warranty
External
United Kingdom
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
2 km
Status Indicators
Port duplex mode, power, link/activity
Flow control, auto-negotiation, half duplex mode, full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3af
1 x Ethernet 10Base-T/100Base-TX - RJ-45 female , 1 x Ethernet 100Base-FX - SC multi-mode female x 2
FCC, RoHS
PoE
External power adapter
AC 120/230 V
7.3 cm
10.8 cm
2.3 cm
170 g
50 °C
10 - 90%
