StarTech.com Fiber Breakout Cable 5m MPO / MTP to LC
Quicklinx: DXF7WS00 Mfr#: MPO8LCPL5M
Length: 5m
Colour: Aqua
£240.02 ex VAT
£288.02 inc VAT
Fan out eight fibers from a 40Gbps MPO connection to four 10Gbps LC connections. This MPO/MTP to 8x LC breakout cable lets you fan out a single 40Gbps connection from a 40GBase-SR4 QSFP+ transceiver to four 10Gbps LC SFP+ transceivers.
The push-and-pull tabs optimize accessibility and let you install or remove the connectors with one hand, without using additional tools. Plus, the slim uniboot design of the LC connectors saves space and improves cable management.
The MPO cable is housed in a plenum-rated jacket and is ideal for installations where CMP fire rating is required.
Each OM3 fiber cable has been individually tested for insertion loss and return loss. The full test report is included in each cable bag.
StarTech.com 5m 15ft MPO/ MTP to LC Breakout Cable - Push/Pull Tab - Plenum - breakout cable - 5 m - aqua
Breakout cable - OM3
Fibre optic
Type of Fibre Optics
Multimode
Plenum
Length
5 m
Core / Cladding Diameter
50 / 125 micron
Connector
MTP/MPO multi-mode - female - push/pull
Connector (Second End)
8 x LC multi-mode - male - push/pull
Aqua
Network Cable Type
Fibre optic
Multimode
50 / 125 micron
Plenum
Length
5 m
84.2 g
Aqua
Connector
RoHS
DXF7 StarTech.com Fiber Breakout Cable 1m MPO / MTP to LC In Stock £176.15
DXF7 StarTech.com Fiber Breakout Cable 10m MPO / MTP to LC In Stock £288.64
DXF7 StarTech.com Fiber Breakout Cable 3m MPO / MTP to LC In Stock £215.71
DXF7 StarTech.com Fiber Breakout Cable 5m MPO / MTP to LC In Stock £240.02
Length: 5m
Colour: Aqua
Price Range Ex VAT: 150 - 300
