Fan out eight fibers from a 40Gbps MPO connection to four 10Gbps LC connections. This MPO/MTP to 8x LC breakout cable lets you fan out a single 40Gbps connection from a 40GBase-SR4 QSFP+ transceiver to four 10Gbps LC SFP+ transceivers.
The push-and-pull tabs optimize accessibility and let you install or remove the connectors with one hand, without using additional tools. Plus, the slim uniboot design of the LC connectors saves space and improves cable management.
The MPO cable is housed in a plenum-rated jacket and is ideal for installations where CMP fire rating is required.
Each OM3 fiber cable has been individually tested for insertion loss and return loss. The full test report is included in each cable bag.
- StarTech.com 2m 6ft MPO / MTP to LC Breakout Cable - Push/Pull Tab - Plenum - breakout cable - 2 m - aqua
- Breakout cable - OM3
- Technology
- Fibre optic
- Type of Fibre Optics
- Multimode
- Plenum
- Length
- 2 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- MTP/MPO multi-mode - female - push/pull
- Connector (Second End)
- 8 x LC multi-mode - male - push/pull
- Aqua
- Limited lifetime warranty
- Network Cable Type
- Technology
- Fibre optic
- Multimode
- 50 / 125 micron
- Plenum
- Length
- 2 m
- 47.8 g
- Aqua
- Connector
- RoHS
StarTech.com Fiber Breakout Cable 1m MPO / MTP to LC | In Stock | £176.15 |
StarTech.com Fiber Breakout Cable 10m MPO / MTP to LC | In Stock | £288.64 |
StarTech.com Fiber Breakout Cable 2m MPO / MTP to LC | In Stock | £226.25 |
StarTech.com Fiber Breakout Cable 3m MPO / MTP to LC | In Stock | £215.71 |
StarTech.com Fiber Breakout Cable 5m MPO / MTP to LC | In Stock | £240.02 |
