StarTech.com Extreme Networks 10320 Comp QSFP+ SM Module - 40GBase-LR4
Quicklinx: FJ9KWS00 Mfr#: 10320-ST
The 10320-ST is an Extreme Networks 10320 compatible fiber transceiver module that has been designed, programmed and tested to work with Extreme Networks brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-LR4 compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This QSFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Extreme Networks 10320 Compatible QSFP+ Module, 40GBASE-LR4, Single Mode (SMF) Fiber, 40GE Gigabit Ethernet QSFP+, LC Connector, 10 km, 1270nm to 1330nm, DDM, 40Gbps QSFP Plus - Lifetime Warranty (10320-ST) - QSFP+ transceiver module - 40 Gigabit LAN
QSFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
40GBase-LR4
Data Transfer Rate
40 Gbps
Optical Wave Length
1270-1330 nm
40 Gigabit LAN
Max Transfer Distance
10 km
1.83 cm x 7.2 cm x 1.3 cm
44 g
Plug-in module
Wired
Cabling Type
40GBase-LR4
40 Gigabit LAN
Data Transfer Rate
40 Gbps
Optical Wave Length
1270-1330 nm
10 km
Full duplex mode
IEEE 802.3ba
1 x Ethernet 40GBase-LR4 - LC single-mode female x 2
MTBF
95,832,026 hours
UL, FCC, RoHS, REACH, MSA
2.5 Watt
1.83 cm
7.2 cm
1.3 cm
44 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
