StarTech.com Expansion Slot Rear Exhaust Cooling Fan with LP4 Connector
Customer rating: 4.0* (Write a review)
Quicklinx: 3039WS00 Mfr#: FANCASE
Type: Case Fan
£6.54 ex VAT
£7.84 inc VAT
The StarTech.com PC case exhaust fan is an add-in cooling fan designed to fit in the PCI or ISA expansion slots of any computer. It is used to exhaust warm air out, preventing problems due to overheating components. The exhaust fan inlet faces adjacent PCI or AGP cards and makes a great video card cooler for hot running 3D accelerator cards like the Voodoo, TNT2, GeForce256 and others. A quiet running brushless DC motor coupled with a high efficiency blade design is capable of moving 36 CFM (cubic feet per minute) of air. Power is supplied to the fan using a standard LP4 (hard drive power connector) pass through plug.
StarTech.com Expansion Slot Rear Exhaust Cooling Fan with LP4 Connector system fan kit
System fan kit
Noise Level
32 dB
12 cm x 11 cm
0.2 kg
System fan kit
12 cm
11 cm
0.2 kg
Security Cable Lock
Noise Level
32 dB
Limited warranty - 2 years - carry-in
Customer reviews
Write a review for the StarTech.com Expansion Slot Rear Exhaust Cooling Fan with LP4 Connector here!
Just got mine
Reviewed by Nicky Thomas. Review Posted 08/01/2008
Seems like a good little thing, really easy to set up. Not noticed any difference in my Graphics Card Temprature still lurking around the 62'C mark.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
i haven't bought this, but....
Reviewed by Michael. Review Posted 09/05/2007
the person who last reviewed this said it pivited freely, looking at the picture (it may not be correct) it look like it should fit in the slot next to the graphics card (where a pci slot is or agp ect) i don't know where Anonymous tried to put it as it should fit there know truoble
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Startech.com case exhaust fan.
Reviewed by Duncan. Review Posted 07/11/2007
I have and use two of these in the back of my computer. I have had no over heating problems, could do with a small tab to go into empty pci slot that they cover, this would stop any movment. overall i think these are great.
  • Overall 4*
  • Ease of use 4*
Read all 5 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: Case Fan
Price Range Ex VAT: 0 - 50
