Prevents dangerous electrostatic buildup while working on electronics. This durable ESD anti-static wrist strap helps you protect your valuable computer equipment from dangerous static electricity. The wrist strap/grounding bracelet offers hassle-free electrostatic grounding, allowing you to work freely on your computer without having to worry about static build-up, which could potentially damage computer components.
Designed and constructed to exceed IBM and US military static control standards, the grounding bracelet/ESD wrist strap is made from the highest quality static dissipative material to ensure the safe operation of your equipment.
- StarTech.com ESD Anti Static Wrist Strap Band with Grounding Wire - AntiStatic Wrist Strap - Anti-static wrist band (SWS100) - anti-static wrist band
- Product Type
- 1-year warranty
- Designed For
- P/N: M3013
- Product Type
- Limited warranty: - 1 year
- Designed For
- P/N: M3013
StarTech.com ESD Anti Static Wrist Strap | In Stock | £7.40 |
StarTech.com Desktop Anti-Static Mat | In Stock | £20.64 |
