StarTech.com eSATAp / eSATA or USB 3.0 External 2.5in SATA III 6 Gbps Hard Drive Enclosure with UASP
Quicklinx: 9YY5WS00 Mfr#: S251SMU33EP
Type: Storage enclosure
HD Size: 2.5"
21 in stock
£26.16 ex VAT
£31.39 inc VAT
Turn a 2.5" SATA III HDD / SSD into an external hard drive that can connect to your computer through either eSATAp at 6 Gbps, or USB 3.0 with UASP at 5 Gbps. The S251SMU33EP USB 3.0 / eSATAp drive enclosure turns a 2.5in SATA hard drive (HDD) or solid state drive (SSD) into an external portable hard drive that can connect to any USB or eSATA-enabled computer system.
For fast performance and efficient data transfers when connected through eSATA, the enclosure supports full SATA III transfer speeds - up to 6 Gbps. For universal compatibility, the S251SMU33EP can be connected through USB 3.0 with transfer speeds up 5 Gbps plus support for UASP, which delivers performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller to utilize the full potential of your SATA III hard drives.
Designed for maximum portability, the S251SMU33EP doesn't require an external power adapter when connected to an eSATAp (USB + eSATA combo) host port.
The 2.5in enclosure supports the fastest drive technologies including SATA III (6 Gbps), hybrid drives and solid state drives (SSD), saving you time by ensuring you're getting the most out of your drive performance.
To ensure compatibility with your computer system, the S251SMU33EP supports all of the leading operating systems, including: Microsoft Windows, Apple OSX, Linux, and Google Chrome OS.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com USB 3.0 or eSATAp / eSATA 2.5in SATA III HDD Enclosure - UASP - storage enclosure - SATA 6Gb/s - eSATA 6Gb/s, USB 3.0
Storage enclosure - external
Bus Type
Silver
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Aluminium / plastic
Power Source
USB bus
7.7 cm x 12.5 cm x 0.95 cm
96 g
P/N: HB30C1A1CPD, HB30C3APD, HB30C3APDW, HB30C4AFPD
2.5"
Host Bus
Product Material
Aluminium / plastic
Silver
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
1
ASMedia ASM1153E / ASM1456
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - SATA combo
1 x eSATA 6Gb/s - 11 pin USB/eSATA , 1 x USB 3.0 - 10 pin Micro-USB Type B
Screwdriver
1 x USB cable - external , 1 x eSATA cable - external , 1 x USB power adapter - external
USB powered, LED indicator, UASP transfer protocol, tested with up to 2TB 7200 RPM 2.5" hard drives
Mounting Kit
Included
FCC, RoHS
Power Source
USB bus
7.7 cm
12.5 cm
0.95 cm
96 g
10 - 90%
9YY5 StarTech.com 3 ft Shielded External eSATA Cable M/M In Stock £6.82
9YY5 StarTech.com 2 Port SATA to eSATA Slot Plate Bracket In Stock £6.26
9YY5 StarTech.com 1ft Low Profile SATA to eSATA Plate Adapter In Stock £4.50
9YY5 StarTech.com 2 Port Low Profile SATA to eSATA Plate Adapter In Stock £6.73
9YY5 StarTech.com 2 Port Low Profile SATA to eSATA Plate Adapter - F/M In Stock £7.02
9YY5 StarTech.com 1 Port SATA to eSATA Slot Plate Bracket In Stock £4.82
9YY5 StarTech.com 18in 1 Port SATA to eSATA Plate Adapter In Stock £6.26
9YY5 StarTech.com eSATAp / eSATA or USB 3.0 External 2.5in SATA III 6 Gbps Hard Drive Enclosure with UASP In Stock £26.16
HD Size: 2.5"
Price Range Ex VAT: 0 - 50
