StarTech.com eSATA / USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP
Quicklinx: 9XDDWS00 Mfr#: SDOCKU33EBV
Type: Storage controller
HD Size: 2.5", 3.5"
£38.30 ex VAT
£45.96 inc VAT
Dock your 2.5in or 3.5in SATA 6 Gbps SSDs/HDDs over eSATA or USB 3.0 with UASP. Theversatile SDOCKU33EBV UASP-enabled USB 3.0 / eSATA docking station makes it easy for you to connect and swap 2.5in or 3.5in SATA III hard drives (HDD) and solid state drives (SSD), with the option to connect through either USB or eSATA.
For convenient compatibility and time-saving performance, the SDOCKU33EBV docking station can be connected through USB 3.0, with support for full USB 3.0 bandwidth (5 Gbps) as well as UASP, which delivers performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller. For fast performance and efficient data transfers, the dock also supports the full SATA III bandwidth of 6 Gbps when connected through eSATA.
With support for large capacity SATA I/II/III drives (tested up to 6TB), as well as 2.5in or 3.5in drives, this HDD/SSD docking station makes it easy to maximize the storage/backup capabilities of your computer using virtually any SATA drive.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in IDE hard drive into a SATA hard drive dock.
To ensure compatibility with your computer system, the SDOCKU33EBV supports all of the leading operating systems, including: Microsoft Windows (8/7/Vista/XP/Server 2008/Server 2003), Apple OSX (10.9/10.8/10.7/10.6), Linux, and Google Chrome OS.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com eSATA / USB 3.0 SATA III Docking Station with UASP - USB 3.0 Hot-Swap Dock supports 2.5"/3.5" SATA HDD/SSD (SDOCKU33EBV) - storage controller - eSATA - USB 3.0
Storage controller - external
Bus Type
USB 3.0
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
eSATA
Data Transfer Rate
600 MBps
Supported Devices
Hard drive
AC 120/230 V
Linux, Microsoft Windows Server 2003, Apple MacOS X 10.6, Microsoft Windows Server 2008, Google Chrome OS, Apple MacOS X Lion 10.7, Microsoft Windows Vista / XP / 7 / 8, Apple MacOS X 10.8, Apple MacOS X 10.9
9.2 cm x 13.9 cm x 5.3 cm
360 g
P/N: SATDUP11IMG, SVA12M2NEUA, SVA12M5NA
2.5", 3.5"
Host Bus
USB 3.0
Storage Controller
eSATA
Data Transfer Rate
600 MBps
Supported Devices
Hard drive
Bays
1 x eSATA - SATA
1 x USB 3.0 - 9 pin USB Type B
1 x USB cable - external , 1 x eSATA cable - external
LED indicator, tested with up to 6TB 7200 RPM hard drives
Plug and Play, FCC, RoHS
Power adapter
AC 120/230 V
9.2 cm
13.9 cm
5.3 cm
360 g
5 °C
35 °C
20 - 80%
9XDD StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £9.34
9XDD StarTech.com 2 Port Low Profile SATA to eSATA Plate Adapter In Stock £6.78
9XDD StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £8.03
9XDD StarTech.com 2 Port Low Profile SATA to eSATA Plate Adapter - F/M In Stock £7.12
9XDD StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP In Stock £32.73
9XDD StarTech.com eSATA / USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP In Stock £38.30
HD Size: 2.5"
HD Size: 3.5"
Price Range Ex VAT: 0 - 50
