This DVI Video Extender system includes a local (transmitter) unit and a remote (receiver) unit, providing an out-of-the-box solution for extending DVI-Digital video over Cat5/UTP cable.
The DVI over VGA extender lets you transmit the DVI-D signal over Category 5e (CAT5e) cabling at distances up to 150ft (50m) from source to display, while providing display resolutions of up to 1600x1200 on the display.
This cost-effective video extension solution is easy to set up and use, and both local and remote units offer a compact form factor that requires minimal install space, making it ideal for any small point to point digital signage application.
- StarTech.com DVI Video Extender over Cat5 - video extender
- Video extender
- Form Factor
- External
- Localisation
- United Kingdom
- Transmission Medium
- CAT 5
- Max Transfer Distance
- 50 m
- 2-year warranty
- Video extender
- Form Factor
- External
- Black
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- Max Resolution
- 1600 x 1200 @ 60 Hz
- 50 m
- Status Indicators
- Power
- 1 x display / video - DVI-Analog/Digital (dual link) - 24+5 pin combined DVI
- FCC, RoHS
- Power Device
- External power adapter
- Installed Qty
- 2
- Limited warranty - 2 years
StarTech.com 10 ft DVI-I Dual Link Digital Analog Monitor Extension Cable M/F | In Stock | £16.86 |
StarTech.com DC Power Adapter - 5V, 2A | In Stock | £10.25 |
