Connect your VGA Display to a DVI-I source. The DVIVGAMF10PK 10-pack of DVI-I to VGA Adapters offers a cost-effective option when you have multiple DVI-enabled computers to connect to VGA monitors.
At a lower cost per unit, these DVI to VGA adapters convert DVI male connectors to VGA female connectors - a perfect solution for schools, and other organizations to connect DVI-I desktop or laptop computers to VGA monitors or projectors.
The adapters are constructed of high-quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your devices use a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter (DVI2VGACON).
- StarTech.com DVI to VGA Cable Adapter - DVI (M) to VGA (F) - 10 Pack - White - Male DVI to Female VGA (DVIVGAMF10PK) - VGA adapter
- VGA adapter
- Packaged Quantity
- 10 (specifications are for single item)
- Molded, thumbscrews
- Connector
- HD-15 (VGA) - female
- Connector (Second End)
- DVI-I - male
- RoHS
- Beige
- Limited lifetime warranty
- Packaged Quantity
- VGA adapter
- Plated Connector
- Nickel
- Beige
- Connector
- 15 pin HD D-Sub (HD-15) - female
- 24+5 pin combined DVI - male
- RoHS
StarTech.com DVI to VGA Cable Adapter M/F - Black - 10 Pack | In Stock | £26.92 |
