StarTech.com DVI to VGA Cable Adapter - M/F
Customer rating: 5.0* (Write a review)
Quicklinx: 3ZKQWS00 Mfr#: DVIVGAMF
More than 50 in stock
£4.87 ex VAT
£5.84 inc VAT
The DVIVGAMF DVI-I to VGA Display Adapter (M/F) is used to convert a DVI Male connector to a VGA female connector. The DVI to VGA adapter is constructed of high quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
StarTech.com DVI to VGA Cable Adapter - M/F - VGA adapter
VGA adapter
Connector
DVI-I - male
Connector (Second End)
HD-15 (VGA) - female
Beige
P/N: IP2DVI, SV421DVI, SV221DVI
VGA adapter
Beige
Connector
24+5 pin combined DVI - male
15 pin HD D-Sub (HD-15) - female
StarTech.com 2 Port DVI PS/2 KVM Switch, Ethernet to DVI Video Adapter over IP , StarTech.com StarView DVI KVM Switch SV421DVI
3ZKQ StarTech.com DVI to VGA Cable Adapter - M/F In Stock £4.87
3ZKQ StarTech.com High Resolution Video DVI to VGA Converter In Stock £88.71
3ZKQ StarTech.com DVI to VGA Cable Adapter - Black - M/F In Stock £4.96
3ZKQ StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female In Stock £6.41
3ZKQ StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 In Stock £22.86
3ZKQ StarTech.com DVI to VGA Cable Adapter M/F - Black - 10 Pack In Stock £19.58
3ZKQ StarTech.com 3 ft DVI to VGA Active Converter Cable – DVI-D to VGA Adapter – 1920x1200 In Stock £24.62
3ZKQ StarTech.com DVI to VGA Cable Adapter M/F - 10 pack In Stock £19.58
Customer reviews
Write a review for the StarTech.com DVI to VGA Cable Adapter - M/F here!
Good Stuff
Reviewed by M@ Morgan. Review Posted 20/01/2007
does what it say it should!! why not buy 2!?
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Does what it says!
Reviewed by Matt. Review Posted 14/02/2007
Very good adapter! High quality and does exactly what it says!
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Price Range Ex VAT: 0 - 50
