StarTech.com DVI to VGA Cable Adapter - F/M
Quicklinx: 4LCYWS00 Mfr#: DVIVGAFM
14 in stock
£6.28 ex VAT
£7.53 inc VAT
Connect your DVI-I Display to a VGA video card. The DVIVGAFM DVI to VGA Cable Adapter converts a DVI male connector to a VGA male connector, allowing you to connect devices with VGA output to a DVI input port.
The DVI to VGA cable adapter eliminates the expense of having to upgrade a VGA video source for the sake of compatibility with a newer DVI capable display.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
StarTech.com DVI to VGA Cable Adapter - DVI-I (F) - HD-15 (M) - VGA adapter
VGA adapter
Connector
DVI-I - female
Connector (Second End)
HD-15 (VGA) - male
FCC, RoHS
Beige
VGA adapter
Beige
Connector
24+5 pin combined DVI - female
FCC, RoHS
Price Range Ex VAT: 0 - 50
