Connect your VGA Display to a DVI-I source. The DVIVGAMFBK DVI-I to VGA Adapter (M/F) is used to convert a DVI Male connector to a VGA female connector. The DVI to VGA adapter is constructed of high quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
- StarTech.com DVI to VGA Cable Adapter - Black - M/F - DVI-I to VGA Converter Adapter (DVIVGAMFBK) - VGA adapter
- VGA adapter
- Molded, thumbscrews
- Connector
- DVI-I - male
- Connector (Second End)
- HD-15 (VGA) - female
- RoHS
- Black
- Limited lifetime warranty
- VGA adapter
- Black
- Connector
- 24+5 pin combined DVI - male
- 15 pin HD D-Sub (HD-15) - female
- RoHS
