Use your DVI-I Display with a VGA video card. The DVIVGAFMBK DVI-I to VGA Display Adapter (F/M) is used to convert a DVI male connector to a VGA male connector. The DVI to VGA adapter is constructed of high quality materials, to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer StarTech.com's DVI to VGA Converter DVI2VGACON.
- StarTech.com DVI to VGA Cable Adapter - Black - F/M (DVIVGAFMBK) - VGA adapter
- VGA adapter
- Connector
- DVI-I - female
- Connector (Second End)
- HD-15 (VGA) - male
- Black
- Designed For
- P/N: BNDDKT30CAHV, USB31GEVG, USB3SMDOCKHV
- VGA adapter
- Black
- Connector
- 24+5 pin combined DVI - female
- 15 pin HD D-Sub (HD-15) - male
- Designed For
