StarTech.com DVI to VGA Cable Adapter - Black - F/M
Quicklinx: 7NXPWS00 Mfr#: DVIVGAFMBK
£5.72 ex VAT
£6.86 inc VAT
Use your DVI-I Display with a VGA video card. The DVIVGAFMBK DVI-I to VGA Display Adapter (F/M) is used to convert a DVI male connector to a VGA male connector. The DVI to VGA adapter is constructed of high quality materials, to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer StarTech.com's DVI to VGA Converter DVI2VGACON.
StarTech.com DVI-I to VGA Cable Adapter - Black - F / M - DVI I to VGA Adapter for Your VGA Monitor or Display (DVIVGAFMBK) - VGA adapter
VGA adapter
Connector
DVI-I - female
Connector (Second End)
HD-15 (VGA) - male
P/N: BNDDKT30CAHV, USB31GEVG, USB3SMDOCKHV
VGA adapter
Connector
24+5 pin combined DVI - female
7NXP StarTech.com DVI to VGA Cable Adapter - M/F In Stock £4.87
7NXP StarTech.com DVI to VGA Cable Adapter - F/M In Stock £6.33
7NXP StarTech.com DVI to VGA Cable Adapter - Black - M/F In Stock £5.00
Price Range Ex VAT: 0 - 50
