The DVI2HDMIA DVI to HDMI Converter/Adapter lets you connect a DVI-D source with the accompanying RCA audio signal to an HDMI monitor or HDTV, with support for full HD 1080p (1920x1080) resolution.
A cost-effective alternative to upgrading equipment for compatibility, this small form factor adapter provides a plug-and-play solution for connecting your Mac, PC or home theater device with DVI (digital) output to your television or HDMI monitor. The RCA stereo audio connections integrate the audio signal directly into the HDMI output, so that a single cable can be run to your destination device.
- StarTech.com DVI to HDMI Video Converter with Audio - Video converter - DVI - HDMI - black - DVI2HDMIA - video converter - black
- Video converter
- Max Resolution
- 1920 x 1080
- 1 x DVI-I input - 24+5 pin combined DVI , 1 x audio line-in - RCA x 2 , 1 x HDMI output - 19 pin HDMI Type A
- 2.6 cm x 8.8 cm x 6.8 cm
- Enclosure Colour
- Black
- 1-year warranty
- Video converter
- Max Resolution
- 1920 x 1080
- 1 x DVI-I input - 24+5 pin combined DVI - female , 1 x audio line-in - RCA x 2 - female , 1 x HDMI output - 19 pin HDMI Type A - female
- Voltage Required
- DC 5 V (50/60 Hz)
- 5 Watt
- Plug and Play, FCC, RoHS
- 2.6 cm
- 8.8 cm
- 6.8 cm
- 200 g
- Enclosure Colour
- Black
- Limited warranty - 1 year
- 0 °C
- 70 °C
- 10 - 85%
StarTech.com 6 ft DVI-D Dual Link Cable - M/M | In Stock | £8.14 |
StarTech.com 10 ft DVI-D Dual Link Cable - M/M | In Stock | £12.86 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.68 |
StarTech.com 10 ft HDMI to DVI-D Cable - M/M | In Stock | £9.97 |
StarTech.com DVI to HDMI Video Converter with Audio | In Stock | £60.27 |
StarTech.com 6in Stereo Audio Cable - 3.5mm Male to 2x RCA Female | In Stock | £3.01 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.36 |
