Connect a DVI-I cable to a DVI-D port. StarTech.com's DVIIDVIDFM DVI-I to DVI-D adapter features a male DVI-D (dual link) connector and a DVI-I female connector, essentially turning a female DVI-D (dual link) connector into a female DVI-I connector.
The adapter allows DVI-I cables to be used in Digital only (DVI-D) connections between PC and monitor, eliminating the cost of having to buy a (DVI-D) cable to connect a DVI (digital) display.
- StarTech.com DVI-I to DVI-D Dual Link Video Cable Adapter F/M - DVI adapter - dual link - DVI-I (F) to DVI-D (M) - gray - DVIIDVIDFM - DVI adapter
- Connector
- DVI-I - female
- Connector (Second End)
- DVI-D - male
- RoHS
- Grey
- Limited lifetime warranty
- DVI adapter
- TMDS Links
- Dual link
- Grey
- Connector
- 24+5 pin combined DVI - female
- 24+1 pin digital DVI - male
- RoHS
