Easily convert your dual monitor workstation into a standing desk for greater comfort and productivity. This wall-mounted sit-stand desk for dual monitors is perfect for areas that don't have enough space for a traditional sit-stand desk. Its compact, wall-mounted design combines a dual-monitor arm and a keyboard tray, with easy height adjustments that let you alternate between sitting and standing without disrupting your workflow.
Adjust your working position in one smooth motion. Simply lift the work surface up to 17.2" (436 mm), to elevate your monitor, keyboard and mouse. The monitor mount has a separate height adjustment of up to 4.9" (124 mm) along the column.
This sit-stand monitor arm supports two monitors up to 24" (with weight capacity of 17.6 lb./8 kg). Adjust your monitor for ideal viewing, with -15° to +15° swivel and 0° to 30° tilt, or rotate your monitors up to 360° for portrait or landscape orientation.
The sit-stand desk folds back to the wall, and the keyboard tray folds up to 90°, saving space when not in use. You can move the swing arm left or right (from -90° to 90°) and lower or raise the arm (from -30° to 65°) to make maximum use of your space.
The monitor arm offers plenty of work space, with a large keyboard tray (17.68 x 8.15"/ 449 x 207 mm) and a slide-out tray (8.5 x 8.4" / 217 x 213 mm) that holds your mouse, on the left or right.
- StarTech.com Wall Mount Workstation, Articulating Full Motion Standing Desk w/ Height Adjustable Dual VESA Monitor & Keyboard Tray Arm, Mouse/Scanner Holders, Ergonomic Wall Mounted Desk - Foldable Standing Desk (WALLSTS2) mounting kit - for 2 monitors - black
- Product Type
- Mounting kit
- Mounting Components
- Wall plate, column, 2 crossbars, keyboard tray, monitor arm, 2 x VESA monitor mounts, crossbar mount
- 119.4 cm x 95.8 cm x 92.6 cm
- Tilt
- 0° to 30°
- Pan
- -90° to 90°
- Rotation
- 360°
- Adjustments
- 10.3 kg
- Recommended Use
- 2 monitors
- Recommended Display Size
- 24"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Material
- Plastic, aluminium, steel
- Black
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Package Content
- 4 x washers, 4 x concrete anchors, 4 x M6x12 screws, hex key (5mm), wrench, hex key (2.5mm), hex key (6mm), wall plate, adhesive strip, socket driver, M8x20 screw, 3 x M6x10 screws, VESA monitor mount, 4 x mounting screws, 2 x M6x8 screws, 8 x M4x10 screws
- 2-year warranty
- 119.4 cm
- 95.8 cm
- 92.6 cm
- 10.3 kg
- Material
- Black
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- 2 monitors
- Cable Management
- Integrated cable management
- 24"
- Tilt
- 0° to 30°
- Pan
- -90° to 90°
- Rotation
- 360°
- Adjustments
Dimensions & Weight Details
- Dimensions
- Keyboard tray - width: 44.9 cm, depth: 20.7 cm
- Limited warranty - 2 years
StarTech.com Adjustable CPU Wall Mount | In Stock | £37.24 |
StarTech.com Wall Mounted Sit Stand Desk | In Stock | £359.74 |
StarTech.com Wall Mounted Computer Workstation - Extendable Monitor Arm | In Stock | £383.10 |
