This PCI Express to ExpressCard adapter adds an ExpressCard slot to a PCI Express capable computer. A cost-effective solution, the adapter lets you use your 34/54mm form factor ExpressCards (AirCard, wireless broadband card, etc.) on a desktop PC - eliminating the expense of having to buy a desktop specific add-on card (PCI based, etc.).Designed for use in standard and small form-factor computers, the PCIe to ExpressCard adapter includes both low-profile and standard-sized brackets.
- StarTech.com Dual Profile PCI Express to 34mm and 54mm ExpressCard Adapter Card - ExpressCard adapter - PCIe
- Interface Type
- PCIe
- 60 g
- OS Required
- Microsoft Windows 2000 / XP, Microsoft Windows Vista, Microsoft Windows 2003
- Limited lifetime warranty
- Designed For
- P/N: PCI1PEX1
- Interface Type
- PCIe
- 60 g
- Expansion Slots
- 1 x ExpressCard/54
- Connections
- 1 x USB - 4 pin USB Type B
- Compatible Slots
- 1 x PCI Express x1
- FCC, RoHS
- OS Required
- Limited warranty - lifetime
- Designed For
- StarTech.com PCI to PCI Express Adapter Card
