StarTech.com Dual-Port QSFP+ NIC Card
Quicklinx: DBXYWS00 Mfr#: PEX40GQSFDPI
Wired / Wireless: Wired
Protocol: 40 Gigabit Ethernet
Type: Network adapter
Hurry, only 1 left in stock!
£346.31 ex VAT
£415.57 inc VAT
Get fast, high-bandwidth connectivity with the Dual-Port QSFP+ Network Interface Card. It adds two open QSFP+ slots to your server or workstation. It's ideal for high-demand database servers, virtualized servers and agile data centers that require infrastructure updates with no downtime.
  • Increase your network speed
    The Dual-Port QSFP+ Server NIC card lets you take advantage of the speed and stability of a 40 Gigabit network, with incredible data transfers.
  • Add redundant connections in zero-downtime environments
    With two QSFP+ ports, the PCIe NIC helps to prevent network downtime by adding fault-tolerant connections using two modules, to provide high-bandwidth network links to your mission-critical servers or workstations.
  • Add scalable network connections
    With its open QSFP+ slots, the network interface card supports QSFP+ transceiver modules and is compatible with multimode and single-mode fiber, providing a scalable networking solution.
StarTech.com Dual-Port QSFP+ Server NIC - PCIe - 40G Network Interface Card - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express
Ports
40 Gigabit QSFP+ x 2
40 Gigabit LAN
Data Transfer Rate
40 Gbps
XL710 - Intel
Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x (64-bit) LTS versions, Microsoft Windows Server 2019 (64-bit)
Network adapter
Plug-in card
PCI Express
Ports
Wired
40 Gigabit Ethernet
Data Transfer Rate
40 Gbps
Processor / Memory
XL710 - Intel
2 x 40Gb Ethernet - QSFP+
Price Range Ex VAT: 300 - 500
