Add dual Gigabit Ethernet ports to a client, server or workstation through a PCI Express slot. The ST2000SPEXI PCI Express Dual Port Gigabit Network Card lets you add two gigabit Ethernet ports to a desktop computer through a single, four-lane (x4 or higher) PCI Express slot. Each port is fully compatible with IEEE 802.3/u/ab standards, for 10/100/1000 Mbps auto-negotiation.
This 2-port GbE network card is based on the high-performance Intel I350 chipset, which offers several advanced driver options including IEEE 802.3ad link aggregation / teaming support, enabling you to add additional bandwidth to your system. Support for Jumbo Frames, full-duplex operation and 802.1q VLAN tagging also aid in creating an efficient network configuration.
Also useful for virtualization applications or setting up a dual-homed host configuration, this dual-port network card lets you accommodate several complex network scenarios, to meet your business needs. For added versatility, the controller card is equipped with a standard profile bracket and includes a low-profile/half-height bracket for installation in small form-factor computers.
- StarTech.com Dual Port PCI Express Gigabit Network Card w/ Intel i350 Chip - network adapter
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 2.1 x4
- PCI Specification Revision
- PCIe 2.1
- Ports
- Gigabit Ethernet x 2
- 6.7 cm x 12.1 cm x 1.9 cm
- 90 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- Data Transfer Rate
- 1 Gbps
- TCP/IP, UDP/IP
- Processor
- I350-AM2 - Intel
- IEEE 802.3, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 1588-2008
- System Requirements
- Linux 2.4.x, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- 2 years warranty
- Network adapter
- Form Factor
- Plug-in card
- PCIe 2.1
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- TCP/IP, UDP/IP
- Status Indicators
- Link/activity
- Full duplex capability, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), Jumbo Frames support, teaming support, Large Send Offload (LSO), TCP Segmentation Offload (TSO), tagged VLAN, checksum offload support
Processor / Memory
- Processor
- I350-AM2 - Intel
- 2 x 1000Base-T - RJ-45
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 6.7 cm
- 12.1 cm
- 1.9 cm
- 90 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 85%
