The EC2000S 2-port Gigabit ExpressCard Ethernet Adapter adds 2 10/100/1000Mbps Ethernet ports to an ExpressCard-enabled laptop, or small form factor system, enabling you to connect to two separate physical networks simultaneously with dedicated bandwidth, or providing full dedicated bandwidth to virtual machines.
Supporting features such as NDIS5 checksum and large send offload for lower CPU utilization, Wake-on-LAN (WOL) and Remote Wake-up power management, jumbo frames and VLAN tagging, this ExpressCard Ethernet Adapter is ready to handle a wide variety of scenarios.
With a 34mm ExpressCard form factor, this compact and portable Gigabit Ethernet Adapter will fit in any ExpressCard-enabled system.
- StarTech.com Dual Port ExpressCard Gigabit Laptop Ethernet NIC Network Adapter Card - network adapter - ExpressCard - Gigabit Ethernet x 2
- Network adapter
- Form Factor
- Plug-in module
- Interface (Bus) Type
- ExpressCard/34
- Ports
- 3.4 cm x 11.6 cm x 2.1 cm
- 150 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- Data Transfer Rate
- 1 Gbps
- TCP/IP, UDP/IP
- Processor
- 1 x Realtek Semiconductor RTL8111E
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
- Limited lifetime warranty
- Network adapter
- Form Factor
- Plug-in module
- ExpressCard/34
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- TCP/IP, UDP/IP
- Status Indicators
- Port transmission speed, link/activity
- Flow control, full duplex capability, remote Wake Up, hot swap module replacement, auto-negotiation, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), half duplex mode, Jumbo Frames support
Processor / Memory
- Processor
- 2 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x ExpressCard/34
- Plug and Play, FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 3.4 cm
- 11.6 cm
- 2.1 cm
- 150 g
- Limited warranty - lifetime
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card | In Stock | £14.89 |
StarTech.com 1 Port PCI 10/100/1000 32 Bit Gigabit Ethernet Network Adapter Card | In Stock | £12.85 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter | In Stock | £23.31 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black | In Stock | £30.93 |
StarTech.com Dual Port Gigabit PCI Express Server Network Adapter Card - PCIe NIC | In Stock | £86.90 |
