StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter
Quicklinx: 9D6YWS00 Mfr#: 25SAT22MSAT
Hurry, only 1 left in stock!
£43.44 ex VAT
£52.12 inc VAT
Build a RAID array with two mSATA SSDs that can be installed into a single 2.5in SATA bay. Vastly increase system performance by adding a dual mSATA SSD RAID array into any 2.5" SATA HDD application with the 25SAT22MSAT mSATA to SATA adapter.
Utilize the full potential of your SATA III controller, with mSATA SSDs reducing your Data transfer bottleneck with file transfer speeds up to 6 Gbps. mSATA SSDs also save you money by reducing your power consumption over regular platter drives.
You can achieve greater SSD capacity, or data redundancy with the Dual SSD controller supporting multiple RAID modes (RAID 0, 1, BIG). The SSD adapter also supports non-RAID operation (JBOD) when paired with a port-multiplying SATA controller, so both drives can be used independent of one another.
Help protect the health of your drive with an open-frame design ensuring maximum heat dissipation.
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter - 2x mSATA SSD to 2.5in SATA Adapter with RAID and 7mm Open Frame Housing (25SAT22MSAT) - storage controller - mSATA - SATA 6Gb/s
Storage controller - internal
Bus Type
SATA 6Gb/s
mSATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Channel Qty
2
RAID Level
RAID 0, RAID 1, JBOD, BIG
7 cm x 10 cm x 0.7 cm
40 g
P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F
Host Bus
SATA 6Gb/s
Storage Controller
mSATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Channel Qty
2
RAID Level
2 x - mSATA
1 x SATA 6Gb/s - 15 pin Serial ATA power
Mounting Kit
Included
FCC, RoHS
7 cm
10 cm
0.7 cm
40 g
-40 °C
85 °C
