Product
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter
Quicklinx: 9D6YWS00 Mfr#: 25SAT22MSAT
Type: Storage controller
5 in stock
£38.35 ex VAT
£46.02 inc VAT
Standard delivery Delivered within 3-5 working days
Build a RAID array with two mSATA SSDs that can be installed into a single 2.5in SATA bay. Vastly increase system performance by adding a dual mSATA SSD RAID array into any 2.5" SATA HDD application with the 25SAT22MSAT mSATA to SATA adapter.
Utilize the full potential of your SATA III controller, with mSATA SSDs reducing your Data transfer bottleneck with file transfer speeds up to 6 Gbps. mSATA SSDs also save you money by reducing your power consumption over regular platter drives.
You can achieve greater SSD capacity, or data redundancy with the Dual SSD controller supporting multiple RAID modes (RAID 0, 1, BIG). The SSD adapter also supports non-RAID operation (JBOD) when paired with a port-multiplying SATA controller, so both drives can be used independent of one another.
Help protect the health of your drive with an open-frame design ensuring maximum heat dissipation.
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter - storage controller - mSATA - SATA 6Gb/s
Storage controller - internal
Bus Type
SATA 6Gb/s
mSATA
Data Transfer Rate
6 GBps
Supported Devices
Hard drive, solid state drive
Channel Qty
2
RAID Level
RAID 0, RAID 1, JBOD, BIG
7 cm x 10 cm x 0.7 cm
40 g
2 years warranty
Host Bus
SATA 6Gb/s
Storage Controller
mSATA
Data Transfer Rate
6 GBps
Supported Devices
Channel Qty
2
RAID Level
2 x - 52 pin mini-SATA
1 x SATA 6Gb/s - 15 pin Serial ATA power
Mounting Kit
Included
FCC, RoHS
7 cm
10 cm
0.7 cm
40 g
-40 °C
85 °C
9D6Y StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £3.38
9D6Y StarTech.com 12in Latching SATA Cable In Stock £3.33
9D6Y StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mounting Kit In Stock £6.34
9D6Y StarTech.com 12in SATA Serial ATA Cable In Stock £3.05
9D6Y StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £4.45
9D6Y StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £3.41
9D6Y StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.38
9D6Y StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £38.35
Price Range Ex VAT: 0 - 50
