Adjustable Dual Monitor Mount Synced Height Adjustment Easy-Grip Handle. This Dual Monitor Arm lets you mount two 17" to 32" VESA mount monitors, each weighing up to 17.6 lb. (8 kg), onto a single low-profile base. It gives you flexible desk-clamp or grommet-hole mounting, letting you save space while creating an ergonomic workspace in any office environment.
Free Up Desk Space
With a stable crossbar design, the adjustable height dual monitor stand lets you create more usable work space by mounting your monitors side by side on a single base.
Optimal Viewing
The computer screen stand features one-touch height adjustment. The smooth +/- 10° tilt motion and +/- 90° swivel make it easy to find the optimal viewing angle. You can also rotate each display 180° for portrait or landscape viewing and laterally adjusted along the crossbar length.
Flexible Installation
The adjustable dual monitor mount is easy to install, with the desk-clamp or grommet mount (hardware included). Integrated cable management keeps your workspace organized. It works well with most desks, including sit-stand workstations.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
ARMSLMBARDUO is backed by a 5-year StarTech.com warranty and free lifetime technical support.
Free up desk space
With a stable crossbar design, the adjustable height dual monitor stand lets you create more usable work space by mounting your monitors side by side on a single base. -
Optimal viewing
The computer screen stand features one-touch height adjustment. The smooth +/- 10° tilt motion and +/- 90° swivel make it easy to find the optimal viewing angle. You can also rotate each display 180° for portrait or landscape viewing and laterally adjusted along the crossbar length. -
Flexible installation
The adjustable dual monitor mount is easy to install, with the desk-clamp or grommet mount. Integrated cable management keeps your workspace organized. It works well with most desks, including sit-stand workstations.
- StarTech.com Desk Mount Dual Monitor Arm, Ergonomic Dual Monitor VESA Mount for 32" 17.6lbs (8kg) Displays, Crossbar Handle for Synchronized Full Motion, Height Adjustable, C-Clamp/Grommet - Small Footprint Design (ARMSLMBARDUO) mounting kit - adjustable arm - for 2 monitors - black
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- 56.9 cm x 83.2 cm x 59.5 cm
- Tilt
- -10° to 10°
- Rotation
- -180° to 180°
- Swivel
- -90° to 90°
- Adjustments
- Height, tilt, swivel, rotation
- 7.3 kg
- Recommended Use
- 2 monitors
- Recommended Display Size
- 17"-32"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Material
- Heavy duty steel
- Black
- Package Content
- 8 x M4x12 screws, hex key (4mm), hex key (3mm), grommet plate, hex key (6mm), 8 x M5x12 screws, 4 x countersunk screws, grommet screw, 2 x flat head hex screws, 4 x button head hex screws
- 5-year warranty
- 56.9 cm
- 83.2 cm
- 59.5 cm
- 7.3 kg
- Material
- Heavy duty steel
- Black
- Package Content
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- 2 monitors
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- 17"-32"
- Tilt
- -10° to 10°
- Rotation
- -180° to 180°
- Swivel
- -90° to 90°
- Adjustments
- Max Load Weight
- 8 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 22.5 cm x 89.5 cm x 15 cm / 8.8 kg
- Limited warranty - 5 years
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £135.75 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £157.69 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £212.26 |
StarTech.com Vertical Dual Monitor Mount | In Stock | £67.16 |
StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors | In Stock | £187.20 |
StarTech.com Desk Mount Dual Monitor Arm - Crossbar | In Stock | £96.45 |
StarTech.com Desk Mount Dual Monitor Arm - Dual Swivel Articulating | In Stock | £95.58 |
StarTech.com Dual Desk Mount Monitor Arm - Built-in 2-port USB and 3.5 mm | In Stock | £157.78 |
StarTech.com Desk Mount Monitor Arm/Max 32" | In Stock | £157.56 |
StarTech.com Dual Monitor Desk Mount | In Stock | £203.80 |
StarTech.com Six-Monitor Desk Mount/Max 32" | In Stock | £270.47 |
