Extend two HDMI signals to distances up to 295 ft. (90m) over a single CAT5 or CAT6 cable. This HDMI over CAT6 extender lets you extend two HDMI sources up to 90 m (295 ft.), to individual HDMI displays over a single CAT6 cable. Designed for a simple, tidy setup, the extender also supports bi-directional IR control for added flexibility.
Reduce the need for additional equipment and cables, by extending two HDMI connections with a single CAT6 cable. Running only one cable can save cost on installation or enable you to extend two HDMI signals using an existing cable run. You can also use this 1080p HDMI extender to run separate video signals to the same display, for mission critical digital signage applications where if one signal goes down, the other can easily be swapped in it's place.
With bi-directional IR control, you can control your devices from either end of the extension, such as a Blu-ray player and laptop on one end and two TV displays on the other. The extender includes an IR kit with discreet dongles that easily connect to both your transmitter and receiver, enabling you to remotely control any device you choose from either side of your extension.
The simplicity of one-cable setup avoids the hassle of running multiple cables, while also reducing potential failure points. The included mounting hardware offers professional mounting options ideal for public spaces such as offices or auditoriums.
- StarTech.com Dual HDMI over CAT5e / CAT6 Extender - 1080p over CAT6 or CAT5e - Up to 295 ft. (90m) (ST222HDBT) - video/audio/infrared extender - HDMI - TAA Compliant
- Video/audio/infrared extender
- Form Factor
- External
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- Data Link Protocol
- HDMI
- Transmission Medium
- CAT 5e/6
- Max Transfer Distance
- 90 m
- Power
- AC 120/230 V
- 13 cm x 15.8 cm x 4.3 cm
- 200 g
- TAA Compliant
- 2-year warranty
- Form Factor
- External
- Localisation
- Connectivity Technology
- Wired
- HDMI
- 90 m
- Status Indicators
- Link OK, status
- 7.1 channel audio support
- 2 x HDMI (input) - 19 pin HDMI Type A female , 2 x HDMI (output) - 19 pin HDMI Type A female , 2 x IR (input) - mini jack female , 2 x IR (output) - mini jack female , 1 x SPDIF (input) - TOSLINK female , 1 x SPDIF (output) - TOSLINK female , 1 x microphone (input) - mini jack female , 1 x microphone (output) - mini jack female , 1 x headphones (input) - mini jack female , 1 x headphones (output) - mini jack female , 2 x serial - DB-9 male
- Included Accessories
- IR receiver, IR transmitter, 8 rubber feet
- Cables Included
- 1 x network cable
- Mounting Kit
- Included
- FCC, RoHS
- TAA Compliant
- Power Device
- External power adapter
- Installed Qty
- 1
- Voltage Required
- AC 120/230 V
- 13 cm
- 15.8 cm
- 4.3 cm
- 200 g
- Shipping Weight
- 256 g
- Limited warranty - 2 years
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.94 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.82 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.74 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £5.00 |
StarTech.com HDBaseT Extender Kit - 4K | In Stock | £317.80 |
StarTech.com VGA DP & HDMI Over CAT5 Switch | In Stock | £516.71 |
