StarTech.com Dual Bay Gigabit NAS RAID Enclosure for 3.5" SATA Hard Drives w/ WebDAV Media Server
Quicklinx: 98FYWS00 Mfr#: S352BMU3N
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Create an external dual 3.5in SATA HDD RAID array you can access over a Gigabit LAN using WebDAV, FTP, and Windows Share services. The S352BMU3N 2-Bay NAS RAID enclosure enables you to build a secure external RAID array with two 3.5" SATA hard drives, and connect it directly to your Gigabit network without a host computer for fast network wide access.
For broad device compatibility, this NAS enclosure features WebDAV allowing you to access files from any web browser-enabled device on the network, such as a computer, Tablet, IPhone, or smartphone. Third party mobile apps are also supported for intuitive and familiar file management.
For hassle-free media integration, the enclosure supports UPnP, and DLNA allowing you to instantly stream videos, photos, and Music directly to a supporting smart televisions, Blu-Ray /Set-top box, and Video Game Consoles.
To achieve greater performance or secure data redundancy the enclosure features a built-in hardware RAID controller, supporting RAID 0, 1, and JBOD.
For easier file sharing, the enclosure supports FTP and SMB services, enabling you to publicly share files over the network or Internet, with the client software of choice.
Increase speed locally with USB DAS (Direct-Attached Storage), enabling you to connect the enclosure to your computer using USB 3.0 to provide transfer speeds up 5 Gbps.
The S352BMU3N maximizes both durability and reliability with a built-in fan, solid aluminum construction.
StarTech.com Dual Bay Gigabit NAS RAID Enclosure for 3.5" SATA Hard Drives w/ WebDAV and Media Server - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
0 (installed) / 2 (max)
11.55 cm x 18.05 cm x 8.5 cm
1.2 kg
North America, United Kingdom, Europe
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, JBOD
Network adapter 10Mb LAN, 100Mb LAN, GigE
AC 120/230 V
Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
11.55 cm
18.05 cm
8.5 cm
1.2 kg
Enclosure Colour
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - 3.5"
Network adapter
DLNA Media Server, WebDAV server
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 3.0 - Type B
1 x network cable
FCC, RoHS
External power adapter
AC 120/230 V
5 °C
35 °C
20 - 80%
98FY StarTech.com 10 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £3.83
98FY StarTech.com 10 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £7.51
98FY StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £4.91
98FY StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £5.08
98FY StarTech.com 1m USB 3 Cable Right Angle BK In Stock £5.80
98FY StarTech.com 15 ft Cat 6 Green Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £4.51
98FY StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.89
98FY StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.03
