Product
StarTech.com Dual Bay 5.25" Trayless Hot Swap Mobile Rack for SATA HDD/SSD
Quicklinx: 95PZWS00 Mfr#: HSB2535SATBK
Type: Storage bay adapter
27 in stock
£39.38 ex VAT
£47.25 inc VAT
Easily connect and hot swap dual 2.5" and 3.5" SATA/SAS hard drives from a 5.25" bay. The HSB2535SATBK Removable 2-drive backplane lets you quickly install and hot-swap drives from the front of your computer, by turning a 5.25" bay into a hot-swappable SATA/SAS interface for you to connect a 3.5" SATA hard drive (HDD) and/or a 2.5" SATA hard drive or solid state drive (SSD).
The hard drive bay interfaces with SATA/SAS, offering two trayless hard drive bays and can be mounted into any 5.25" front bay, to provide a hot-swappable mobile rack. The bays feature ejection levers which allow drives to be installed and removed quickly from the computer system, providing a convenient way to create backups that can then be removed for safekeeping, archiving, or external portable access.
For added versatility the backplane provides support for both SATA and SAS interfaces, an ideal accommodation for enterprise system integration. Plus, to help prevent drive failure, the bay provides excellent heat dissipation with a built-in fan and slotted aluminum enclosure.
StarTech.com Dual Bay 5.25" Trayless Hot Swap Mobile Rack for 2.5" & 3.5" SATA HDD/SSD - storage bay adapter - SATA 6Gb/s / SAS 6Gb/s
Storage bay adapter
Expansion Bays
1 x hot-swap - 3.5" , 1 x hot-swap - 2.5" x 1/8H
Compatible Bay
1 5.25" x 1/2H
18.26 cm x 14.8 cm x 4.2 cm
520 g
2 years warranty
Storage bay adapter
Storage Controller
Bays
2 x SATA 6Gb/s / SAS 6Gb/s
2 - 7 pin external Serial ATA , 1 - 4 PIN internal power
Compatible Bay
1 x internal 5.25" x 1/2H
1 x power cable , 2 x Serial ATA cable - 45.72 cm
Mounting Kit
Included
FCC, RoHS
18.26 cm
14.8 cm
4.2 cm
520 g
-5 °C
35 °C
20 - 80%
95PZ StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £2.95
95PZ StarTech.com 18in Latching SATA Cable In Stock £3.72
95PZ StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £4.32
95PZ StarTech.com 18in Latching Round SATA Cable In Stock £4.16
95PZ StarTech.com 4x SATA Power Splitter Adapter Cable In Stock £4.98
95PZ StarTech.com Dual Bay 5.25" Trayless Hot Swap Mobile Rack for SATA HDD/SSD In Stock £39.38
Price Range Ex VAT: 0 - 50
