Easily connect and hot swap dual 2.5" and 3.5" SATA/SAS hard drives from a 5.25" bay. The HSB2535SATBK Removable 2-drive backplane lets you quickly install and hot-swap drives from the front of your computer, by turning a 5.25" bay into a hot-swappable SATA/SAS interface for you to connect a 3.5" SATA hard drive (HDD) and/or a 2.5" SATA hard drive or solid state drive (SSD).
The hard drive bay interfaces with SATA/SAS, offering two trayless hard drive bays and can be mounted into any 5.25" front bay, to provide a hot-swappable mobile rack. The bays feature ejection levers which allow drives to be installed and removed quickly from the computer system, providing a convenient way to create backups that can then be removed for safekeeping, archiving, or external portable access.
For added versatility the backplane provides support for both SATA and SAS interfaces, an ideal accommodation for enterprise system integration. Plus, to help prevent drive failure, the bay provides excellent heat dissipation with a built-in fan and slotted aluminum enclosure.
- StarTech.com Dual Bay 5.25" Trayless Hot Swap Mobile Rack Backplane for 2.5" and 3.5" SATA/SAS HDD or SSD with Fan (HSB2535SATBK) - storage bay adapter - SATA 6Gb/s / SAS 6Gb/s
- Storage bay adapter
- Expansion Bays
- 1 x hot-swap - 3.5" , 1 x hot-swap - 2.5" x 1/8H
- Compatible Bay
- 1 5.25" x 1/2H
- Interface
- 18.26 cm x 14.8 cm x 4.2 cm
- 520 g
- 2-year warranty
- Designed For
- P/N: 25SAT35HDD, PEXMSATA3422, PEXMSATA343
Storage Controller
- Interface
- Processor
- No CPU
- Bays
- 2 x SATA 6Gb/s / SAS 6Gb/s
- Connections
- 2 - 7 pin external Serial ATA , 1 - 4 PIN internal power
- Compatible Bay
- 1 x internal 5.25" x 1/2H
- Cables Included
- 1 x power cable , 2 x Serial ATA cable - 45.72 cm
- Mounting Kit
- Included
- FCC, RoHS
- Limited warranty - 2 years
- 18.26 cm
- 14.8 cm
- 4.2 cm
- 520 g
- -5 °C
- 35 °C
- 20 - 80%
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.44 |
StarTech.com 18in Latching SATA Cable | In Stock | £5.24 |
StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive | In Stock | £17.78 |
StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane | In Stock | £43.92 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.38 |
StarTech.com 4x SATA Power Splitter Adapter Cable | In Stock | £6.28 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £7.38 |
