StarTech.com Dual 4K TB3 Dock - M.2 - SD
Quicklinx: DVZDWS00 Mfr#: TB3DK2DPM2
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black
Hurry, only 2 left in stock!
£331.48 ex VAT
£397.77 inc VAT
This compact Thunderbolt 3 dock is built for productivity, transforming your Thunderbolt 3 MacBook Pro or Windows laptop into a dual-4K workstation with up to 40Gbps of throughput. The high- performance dock features a PCIe M.2 SSD slot for enhanced data storage, three USB ports, an SD card reader, a Gigabit Ethernet port, a downstream Thunderbolt 3 port for daisy-chaining, plus 85W Power Delivery.
Great for Ultra HD tasks, the dual-4K docking station supports 4K resolution on two monitors: 1x DisplayPort and 1x Thunderbolt 3 USB-C display (4096 x 2160p @60Hz) (USB-C to DP cable or USB-C video adapter may be required).
Connect to a single 5K monitor at 60Hz.
The Thunderbolt 3 dock's built-in PCIe M.2 SSD enclosure supports transfer speeds up to 1500MB/s with the addition of a PCIe M.2 SSD for ultra-fast data access, enhanced storage, and application buffering and caching.
Transfer photos or videos from your SD cards to your Thunderbolt 3 laptop. The dock's SD slot supports SD 4.0 and UHS-II with transfer speeds up to 270MB/s.
Connect peripherals with three USB ports - one USB-C port (10G) with up to 3A charging and two USB-A ports (5G) with Fast-Charge and Sync.
The GbE port (with PXE Boot and WoL support) provides reliable wired network access.
Using a single cable, the Thunderbolt 3 dock provides up to 85W of Power Delivery charging.
StarTech.com Thunderbolt 3 Dock, Dual Monitor 4K 60Hz TB3 Laptop Docking Station with DisplayPort, PCIe M.2 NVMe SSD Enclosure, 85W Power Delivery, SD 4.0 Reader, 10Gbps USB-C, 2 USB-A Hub - 85W Thunderbolt 3 Dock (TB3DK2DPM2) - docking station - Thunderbolt 3 - DP, Thunderbolt - GigE - TAA Compliant
Docking station
Docking Interface
Thunderbolt 3
Video Interfaces
DP, Thunderbolt
23.9 cm x 9.5 cm x 2.5 cm
780 g
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Gigabit Ethernet
Power adapter
TAA Compliant
3-year warranty
P/N: ARMBARDUO, ARMBARDUOV, ARMDUAL, ARMDUAL30, ARMDUALV, ARMSLIMDUO
Docking station
23.9 cm
9.5 cm
2.5 cm
780 g
Enclosure Colour
Storage
Storage Controller
PCI Express
Video
Max Resolution Details
4096 x 2160 - 60 Hz
Gigabit Ethernet
Expansion Slots
1 (total) / 1 (free) x PCI Express Mini Card (M.2) - M.2 2280
1 x USB-C - 24 pin USB-C , 1 x audio / video - DisplayPort - 20 pin DisplayPort , 2 x SuperSpeed USB 3.0 with Fast Charging - 9 pin USB Type A , 1 x network - 1000Base-T - RJ-45 , 1 x USB-C / Thunderbolt 3 with Power Delivery - 24 pin USB-C , 1 x audio - mini-phone 3.5 mm , 1 x microphone - mini-phone 3.5 mm
Input Device
SD card reader
1 x Thunderbolt 3 / USB-C cable - external
Wake on LAN, dual display support, Preboot Execution Environment (PXE) support, 5K Ultra HD, 85W power delivery
FCC
TAA Compliant
Power adapter
Microsoft Windows 7 / 8.1 / 10 (32/64 bits), Apple macOS 10.12, Apple macOS 10.13
Limited warranty - 3 years
DVZD StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £23.00
DVZD StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.26
DVZD StarTech.com DisplayPort to DVI Active Adapter In Stock £22.56
DVZD StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £98.81
DVZD StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £15.59
DVZD StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £20.78
DVZD StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £124.85
DVZD StarTech.com Thunderbolt 3 to Thunderbolt In Stock £87.39
DVZD StarTech.com Monitor Mount - USB Passthrough In Stock £154.18
DVZD StarTech.com Dual Monitor Mount - Stackable In Stock £174.45
DVZD StarTech.com Dual Monitor Stand In Stock £82.93
DVZD StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £23.65
DVZD StarTech.com 1m Thunderbolt 3 40Gbps Cable In Stock £60.21
DVZD StarTech.com Vertical Dual Monitor Stand In Stock £82.72
DVZD StarTech.com Vertical Dual Monitor Mount In Stock £71.79
DVZD StarTech.com Thin Client Mount - VESA In Stock £23.02
DVZD StarTech.com Thunderbolt 3 USB Controller In Stock £147.82
DVZD StarTech.com Mini Thunderbolt 3 Dock - MacBook Pro & Windows - Dual 4K 60Hz DP - Bus Powered In Stock £89.11
DVZD StarTech.com Dual 4K TB3 Dock - M.2 - SD In Stock £331.48
Colour: Black
Stock Status: In stock
