Connect two laptops to just one dock, and share dual monitors, keyboard, mouse, peripherals, and files between both laptops. This KVM docking station for two laptops is the first of its kind. It functions similar to a KVM switch, letting you share your keyboard, video, and mouse between two computers.
Plus, it provides dual-monitor outputs, so you can add two extra displays to your workstation, and then share them with each laptop.
This dock eliminates the frustrations of working with multiple computers. You can save money and desk space by using the same peripheral set with each computer, plus you can easily transfer files between your two laptops. It's a simple yet ultra-efficient method for working with more than one laptop.
The dual-monitor KVM dock supports Windows or Mac laptops, or a combination of both. And for a faster workflow and additional convenience, this specialty docking station lets you share and exchange data between your two computers.
It's perfect for a range of users such as professionals and office workers with multiple laptops, students, and IT technicians. It's ideal for collaboration in classrooms, labs, and boardrooms, as well as many other specialized applications.
This cutting-edge docking station is designed for users with multiple laptops or Windows based tablets. Like a KVM switch, it lets you share your peripherals between two computers, with the added benefit of offering extra monitor connections. With shared docking you can get more work done in less time and avoid the nuisance of plugging and unplugging your laptops while you're using them both at your workstation.
When you're in a hurry, switching control to either computer is effortless using the switch button that's conveniently located on the side of the dock.
You can create a dual-monitor workstation that connects with two laptops if you have DisplayPort and HDMI displays, making it easy to display applications or browsers from either laptop. Alternatively the dock supports a single 4K DP monitor, for 4K x 2K (3840 x 2160p - 30Hz) cinema-quality resolution and vivid picture quality.
In addition to connecting two laptops, this full-featured KVM dock lets you connect up to nine peripherals, and provides all the ports you need. And, with five USB 3.0 ports you can connect more USB devices than most docking stations allow. Plus, every port can be easily shared between each connected laptop.
It's easy to charge your mobile device quickly using the always-on fast-charge port. With several USB 3.0 ports, Gigabit Ethernet, and a headset jack, you can connect multiple peripherals and control them from either laptop.
Unlike some docks, this easy-to-use docking station offers seamless, error-free driver installation which makes it easy to create a dynamic and high-performance workstation.
For an uninterrupted workflow and streamlined convenience this dock integrates file sharing capabilities. Laptop-to-laptop file sharing is faster, more secure, and easier to use than cloud or external storage solutions, plus, you can skip the aggravation of configuring your network to support file sharing.
Using Windows Easy Transfer, or the included PCLinq software, you can easily create files and presentations on your primary laptop, and quickly transfer them to your portable Ultrabook, MacBook, or tablet.
- StarTech.com Dual Monitor KVM Docking Station - for Two Laptops - 4K - File Transfer - Universal Laptop Docking Station (USB3DDOCKFT) - docking station - USB - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB
- 82 mm x 27 cm x 3.4 cm
- 374 g
- Black & silver
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 120/230 V
- 3-year warranty
- Designed For
- P/N: ARMBARDUO, ARMDUAL, ARMDUAL30, ARMSLIMDUO, LTLOCK, TB33A1C
- Product Type
- Docking station
- 82 mm
- 27 cm
- 3.4 cm
- 374 g
- Enclosure Colour
- Black & silver
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
- 1 x display / video - 20 pin DisplayPort , 1 x display / video - 19 pin HDMI Type A , 5 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - RJ-45 , 1 x microphone - mini-phone 3.5 mm 4-pole , 2 x SuperSpeed USB 3.0 - 9 pin USB Type B
- Cables Included
- 2 x SuperSpeed USB cable - external
- Security lock slot (cable lock sold separately), LED indicator, UASP transfer protocol
- FCC, RoHS, USB Battery Charging Specification Rev. 1.2
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.8 - 10.12, Google Chrome OS 55 or later, Apple macOS Mojave 10.14
- Limited warranty - 3 years
- 0 °C
- 60 °C
- Designed For
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £9.78 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.12 |
StarTech.com 3.5mm 3 Pin Headset Splitter | In Stock | £6.39 |
StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter | In Stock | £21.47 |
StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video | In Stock | £123.60 |
StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort | In Stock | £94.13 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.56 |
StarTech.com Triple-Video Laptop Dock | In Stock | £101.71 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.26 |
