Connect your HDMI monitor or HDTV to a DisplayPort equipped computer. The StarTech.com DisplayPort to HDMI adapter lets you connect an HDMI-enabled video display to a DisplayPort video source (e.g.DisplayPort video cards, etc.), eliminating the expense of having to upgrade your display for DisplayPort compatibility.
This adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of HDMI video capability.
DP2HDMI is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
This adapter allows for audio pass-through if supported by the video source. Please review the video source manual to confirm support.
- StarTech.com DisplayPort to HDMI Video Converter - video adapter - DisplayPort / HDMI - 24 cm
- Cable
- Video adapter - DisplayPort / HDMI
- Length
- 24 cm
- Black
- Connector
- DisplayPort - male
- Connector (Second End)
- HDMI - female
- 2 years warranty
- Designed For
- P/N: SV231DPUA, VS421DP, SV431DPUA, SV231DPU
- Cable Type
- Video adapter
- Interface Supported
- Length
- 24 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 19 pin HDMI Type A - female
- Limited warranty - 2 years
- Designed For
- StarTech.com 4 Port DisplayPort Video Switch with Audio & IR Remote Control
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £16.05 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £6.14 |
StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable | In Stock | £49.91 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £6.02 |
