StarTech.com DisplayPort to HDMI Video Adapter Converter
Quicklinx: 67B2WS00 Mfr#: DP2HDMI
More than 50 In Stock
£12.84 ex VAT
£15.40 inc VAT
Connect your HDMI monitor or HDTV to a DisplayPort equipped computer. The StarTech.com DisplayPort to HDMI adapter lets you connect an HDMI-enabled video display to a DisplayPort video source (e.g.DisplayPort video cards, etc.), eliminating the expense of having to upgrade your display for DisplayPort compatibility.
This adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of HDMI video capability.
DP2HDMI is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
This adapter allows for audio pass-through if supported by the video source. Please review the video source manual to confirm support.
StarTech.com DisplayPort to HDMI Adapter - 1920 x 1200 - DP to HDMI Converter - Plug and Play DisplayPort to HDMI Dongle (DP2HDMI) - adapter - DisplayPort / HDMI - 24 cm
Cable
Adapter - DisplayPort / HDMI
Length
24 cm
Connector
DisplayPort - male
Connector (Second End)
HDMI - female
3-year warranty
P/N: DPPNLFM3, DPPNLFM3PW, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, SV231DPU, SV231QDPU34K, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
Cable Type
Adapter
Interface Supported
DisplayPort / HDMI
Length
24 cm
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - female
Limited warranty - 3 years
67B2 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.28
67B2 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.84
67B2 StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £11.50
67B2 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.86
67B2 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.98
67B2 StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £9.42
67B2 StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £13.65
67B2 StarTech.com HDMI or DVI to DisplayPort Active Converter In Stock £82.20
67B2 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.38
67B2 StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £13.67
67B2 StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black In Stock £21.85
67B2 StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.92
67B2 StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £21.47
67B2 StarTech.com 3ft DP to HDMI cable - 4K In Stock £14.50
67B2 StarTech.com 6 ft DP to HDMI cable - 4K In Stock £15.82
67B2 StarTech.com DisplayPort to HDMI - 4K In Stock £15.02
67B2 StarTech.com HDMI to DisplayPort Converter - 4K In Stock £39.46
67B2 StarTech.com 5m DisplayPort to HDMI Cable - 4K In Stock £22.64
67B2 StarTech.com 3m DisplayPort to HDMI Cable - 4K In Stock £21.01
67B2 StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £23.58
67B2 StarTech.com mDP to Dual-Link DVI Adapter In Stock £93.65
