2-in-1 Video Adapter Mac & Windows HDR. This DisplayPort to HDMI VGA adapter offers a portable solution for connecting your DP laptop to a VGA or HDMI display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
Two-in-One Video Connectivity with Travel in Mind
Avoid the hassle of carrying different adapters, with a 2-in-1 DisplayPort monitor adapter. Featuring both VGA and HDMI outputs, you can conveniently connect your laptop to any HDMI or VGA-equipped display, using this multiport video converter.
With its small footprint and lightweight design, the travel adapter fits easily into your laptop bag, making it perfect for professionals on the go.
Astonishing 4K Picture Quality
The HDMI output on this DisplayPort video adapter lets you harness the video capabilities that are built into your computer's DP connection, delivering the astonishing quality of UHD to your 4K 60Hz HDMI display. Plus, the VGA output supports HD resolutions up to 1920 x 1080, ensuring you won't have to sacrifice picture quality when connected to a VGA monitor or projector.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
Hassle-Free Setup
With no additional software or drivers to install, this DP (male) to HDMI (female) and VGA (female) dongle offers a plug-and-play setup for a user-friendly experience. It allows you to walk into virtually any boardroom ready to present, making a great first impression.
DP2VGAHD20 is backed by a 3-year StarTech.com warranty and free lifetime technical support.
Two-in-one video connectivity with travel in mind
Avoid the hassle of carrying different adapters, with a 2-in-1 DisplayPort monitor adapter. Featuring both VGA and HDMI outputs, you can conveniently connect your laptop to any HDMI or VGA-equipped display, using this multiport video converter. With its small footprint and lightweight design, the travel adapter fits easily into your laptop bag, making it perfect for professionals on the go. -
Astonishing 4K picture quality
The HDMI output on this DisplayPort video adapter lets you harness the video capabilities that are built into your computer's DP connection, delivering the astonishing quality of Ultra HD to your 4K 60Hz HDMI display. Plus, the VGA output supports HD resolutions up to 1920 x 1080, ensuring you won't have to sacrifice picture quality when connected to a VGA monitor or projector. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging. -
Hassle-free setup
- StarTech.com DisplayPort to HDMI VGA Adapter, DisplayPort 1.2 HBR2 to HDMI 2.0 (4K 60Hz) or VGA 1080p Converter Dongle, DP to HDMI or VGA Monitor Adapter, Digital Video Display Adapter - Multiport Video Dongle (DP2VGAHD20) - adapter - DisplayPort / HDMI / VGA - 23.2 cm
- Cable
- Adapter - DisplayPort / HDMI / VGA
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Length
- 23.2 cm
- Black
- Connectors
- DisplayPort - male (input)
- Connectors (Second End)
- HDMI - female (output) , HD-15 (VGA) - female (output)
- 4K support
- 3-year warranty
- Cable Type
- Adapter 4K support
- Interface Supported
- Length
- 23.2 cm
- HDR support, ITE Tech IT6564 chipset
- Black
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- Connectors
- 20 pin DisplayPort - male (input)
- 19 pin HDMI Type A - female (output) , 15 pin HD D-Sub (HD-15) - female (output)
- FCC, RoHS, REACH
- 6 cm
- 1.5 cm
- 39 g
- Shipping Width
- 8 cm
- Shipping Depth
- 17.7 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 59 g
- Limited warranty - 3 years
