StarTech.com DisplayPort to HDMI Active Video and Audio Adapter Converter - DP to HDMI - White
Quicklinx: 8KRCWS00 Mfr#: DP2HDSW
Connect an HDMI monitor to a Single Mode DisplayPort Video Source. The DP2HDSW Active DisplayPort to HDMI Adapter features audio pass-through support, which enables you to connect both the audio and video that''s output from a DisplayPort-equipped desktop or laptop computer to an HDMI monitor, projector, or display.
Unlike a passive adapter, the DP2HDS actively converts single-mode and dual mode DisplayPort output, which is ideal for graphics cards that do not output dual mode/multi-mode (DP++) signals, such as ATI Eyefinity cards.
This active DP to HDMI adapter is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbol I/O port.
StarTech.com DisplayPort to HDMI Active Adapter Converter DP to HDMI White - video converter - white
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - 20 pin DisplayPort , 1 x HDMI output - 19 pin HDMI Type A
20 cm x 4 cm x 1.5 cm
Enclosure Colour
White
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - 20 pin DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female
HDCP
FCC, RoHS
20 cm
4 cm
1.5 cm
29.8 g
Enclosure Colour
White
Limited warranty - 3 years
60 °C
40 - 85%
