Your basket is empty
StarTech.com DisplayPort to HDMI Active Video and Audio Adapter Converter - DP to HDMI - 1920x1200
Quicklinx: 8G3PWS00 Mfr#: DP2HDS
Connect an HDMI monitor to a DisplayPort Video Source. The DP2HDS Adapter converts DisplayPort to HDMI with audio pass-through support, enabling you to connect a desktop or laptop computer that is equipped with DisplayPort A/V output to an HDMI monitor, projector, or display.
Unlike a passive adapter, the DP2HDS actively converts single mode and dual mode DisplayPort output, which is ideal for graphics cards that do not output dual mode/multi-mode (DP++) signals, such as ATI Eyefinity cards.
The DP to HDMI adapter is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
StarTech.com DisplayPort to HDMI Active Adapter Converter - DP to HDMI - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - 20 pin DisplayPort , 1 x HDMI output - 19 pin HDMI Type A
20 cm x 4 cm x 1.5 cm
Enclosure Colour
2 years warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - 20 pin DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female
HDCP
FCC, RoHS
20 cm
4 cm
1.5 cm
30 g
Enclosure Colour
60 °C
40 - 85%
8G3P StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £14.90
