StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter
Quicklinx: 9NXSWS00 Mfr#: DP2HD4KS
More than 50 In Stock
£21.47 ex VAT
£25.76 inc VAT
Connect an HDMI monitor to a DisplayPort video source. The DP2HD4KS DisplayPort to HDMI adapter enables you to connect a DisplayPort-equipped desktop or laptop computer, such as the HP EliteBook 8570p / 8470p, to an HDMI display. This adapter is compatible with DisplayPort 1.2 & HDMI 4K @ 30 Hz and as a result can support video resolutions up to Ultra HD (4K) as well as the accompanying digital audio up to 7.1 channel surround sound.
With support for resolutions up to Ultra HD (4K) the DP to HDMI adapter ensures you can convert DisplayPort to HDMI while maintaining an astonishing picture quality four times the resolution of high-definition 1080p. The adapter is also backward compatible with previous DisplayPort revisions 1.0/1.1 with support for resolutions up to 1080p.
For a hassle-free setup the DisplayPort to HDMI adapter allows for plug-and-play installation without any additional software or drivers. Plus, with a small footprint and lightweight design, the adapter maximizes portability.
To ensure compatibility with any DisplayPort output the DP adapter offers an active conversion. Active video conversion is required to maintain 4K resolutions when converting DisplayPort to HDMI. An active DP adapter is also ideal for outputting 1080p video resolutions by ensuring compatibility with graphics cards that are not capable of outputting multi-mode DP++ signals (e.g. ATI Eyefinity).
StarTech.com DisplayPort 1.2 to HDMI Adapter - 4K 30Hz - Active Audio Video Converter for DP laptop computers and HDMI Monitor Displays (DP2HD4KS) - video converter
Video converter
Max Resolution
4096 x 2160
1 x DisplayPort input - 20 pin DisplayPort , 1 x HDMI output - 19 pin HDMI Type A
3-year warranty
P/N: DKM30CHDPD, DKM30CHDPDUE, DKWG30DPHPD, DKWG30DPHPDU, SP123DP, SV231QDPU34K, TB3CDK2DP, TB3CDK2DPUE, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPM2, TB3DKM2DP, TB3DKM2DPL, TB3DOCK2DPPD, TB3DOCK2DPPU, USB3DDOCKFT, USB3DOCKH2DP, USB3DOCKHDPC
Video converter
Max Resolution
4096 x 2160
1 x DisplayPort input - 20 pin DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female
Active cable (signal regeneration), HDCP
FCC, RoHS
55 g
Limited warranty - 3 years
70 °C
10 - 85%
9NXS StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.28
9NXS StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.84
9NXS StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £11.50
9NXS StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.86
9NXS StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.98
9NXS StarTech.com HDMI or DVI to DisplayPort Active Converter In Stock £82.20
9NXS StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.38
9NXS StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.92
9NXS StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £21.47
9NXS StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter In Stock £21.13
9NXS StarTech.com 3ft DP to HDMI cable - 4K In Stock £14.50
9NXS StarTech.com 6 ft DP to HDMI cable - 4K In Stock £15.82
9NXS StarTech.com DisplayPort to HDMI - 4K In Stock £15.02
9NXS StarTech.com HDMI to DisplayPort Converter - 4K In Stock £39.46
9NXS StarTech.com 5m DisplayPort to HDMI Cable - 4K In Stock £22.64
9NXS StarTech.com 3m DisplayPort to HDMI Cable - 4K In Stock £21.01
9NXS StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £23.58
9NXS StarTech.com DisplayPort to HDMI Cable In Stock £41.98
