Product
StarTech.com DisplayPort to DVI Video Adapter Converter
Clearance!
Clearance
Quicklinx: 5KM7WS00 Mfr#: DP2DVI
Type: Video
Length: 24cm
Stock Status: Clearance
More than 50 in stock
£15.23 ex VAT
£18.27 inc VAT
Connect your DVI monitor to a DisplayPort equipped computer. The DP2DVI DisplayPort to DVI adapter lets you connect a DVI-D display to a DisplayPort video source (e.g.DisplayPort video cards, etc.), eliminating the expense of having to upgrade to a DisplayPort capable display.
This adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of single link DVI capability. DP2DVI is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com DisplayPort to DVI Video Converter - DisplayPort adapter - 24 cm
DisplayPort adapter - single link
Latched
Length
24 cm
Connector
DisplayPort - male
Connector (Second End)
DVI-D - female
FCC, RoHS
2 years warranty
P/N: SV231DPUA, VS421DP, SV431DPUA, SV231DPU
DisplayPort adapter
TMDS Links
Single link
Latched
Length
24 cm
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - female
FCC, RoHS
2 years warranty
StarTech.com 4 Port DisplayPort Video Switch with Audio & IR Remote Control
5KM7 StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.62
5KM7 StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.60
5KM7 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £15.23
Type: Video
Length: 24cm
Price Range Ex VAT: 0 - 50
