StarTech.com DisplayPort to DVI Video Adapter Converter
Quicklinx: 5KM7WS00 Mfr#: DP2DVI
Type: Video
Length: 24cm
£15.63 ex VAT
£18.75 inc VAT
Connect your DVI monitor to a DisplayPort equipped computer. The DP2DVI DisplayPort to DVI adapter lets you connect a DVI-D display to a DisplayPort video source (e.g.DisplayPort video cards, etc.), eliminating the expense of having to upgrade to a DisplayPort capable display.
This adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of single link DVI capability. DP2DVI is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com DisplayPort to DVI Adapter - 1920x1200 - Display Port to DVI Dongle - Passive DP to DVI-D Adapter (DP2DVI) - DisplayPort adapter - 24 cm
DisplayPort adapter - single link
Latched
Length
24 cm
Connector
DisplayPort - male
Connector (Second End)
DVI-D - female
FCC, RoHS
3-year warranty
P/N: DK30CH2DEP, DK30CH2DEPUE, DPPNLFM3, DPPNLFM3PW, DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, SV231DPU, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
DisplayPort adapter
TMDS Links
Single link
Latched
Length
24 cm
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - female
FCC, RoHS
3-year warranty
5KM7 StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.78
5KM7 StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.72
5KM7 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £15.63
5KM7 StarTech.com DisplayPort DVI Video Adapter Converter In Stock £13.69
5KM7 StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £33.42
5KM7 StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £27.03
5KM7 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.18
5KM7 StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £15.53
5KM7 StarTech.com DisplayPort to DVI Active Adapter In Stock £22.04
5KM7 StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £95.60
Type: Video
Length: 24cm
Price Range Ex VAT: 0 - 50
