StarTech.com DisplayPort to DVI Video Adapter Converter
Quicklinx: 5KM7WS00 Mfr#: DP2DVI
4 due in 1-2 days
Connect your DVI monitor to a DisplayPort equipped computer. The DP2DVI DisplayPort to DVI adapter lets you connect a DVI-D display to a DisplayPort video source (e.g.DisplayPort video cards, etc.), eliminating the expense of having to upgrade to a DisplayPort capable display.
This adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of single link DVI capability. DP2DVI is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
  • Easily connect your DisplayPort computer to a DVI display
    The DP to DVI adapter lets you connect your DisplayPort laptop or desktop computer to a DVI display. The adapter supports plug-and-play connectivity ensuring a hassle-free setup.
  • Works with legacy DVI monitors
    The DisplayPort adapter makes your DP computer fully compatible with existing DVI monitors or projectors in your home or around your office. The DVI connector features nuts that mate with the screws on standard DVI cables, to ensure your video cable won't get disconnected.
  • Designed for maximum portability
    The DisplayPort to DVI converter maximizes portability with a compact, lightweight design, making it the perfect travel accessory to carry with your DisplayPort Ultrabook, fitting easily into your laptop bag or carrying case. This ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
  • Crystal-clear picture quality
    With support for video resolutions up to 1920x1200 or 1080p, you'll be surprised at the picture quality the adapter provides, even when connected to a legacy DVI monitor or projector. The adapter harnesses the video capabilities built into your DP connection to deliver every detail in stunning high-definition. The DP2DVI is backed by a 3-year StarTech.com warranty and free lifetime technical support.
StarTech.com DisplayPort to DVI Adapter - 1920x1200 - Display Port to DVI Dongle - Passive DP to DVI-D Adapter (DP2DVI) - DisplayPort adapter - 24 cm
DisplayPort adapter - single link
Latched
Length
24 cm
Connector
DisplayPort - male
Connector (Second End)
DVI-D - female
FCC, RoHS
3-year warranty
P/N: DK30CH2DEP, DK30CH2DEPUE, DPPNLFM3, DPPNLFM3PW, DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, SV231DPU, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
DisplayPort adapter
TMDS Links
Single link
Latched
Length
24 cm
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - female
FCC, RoHS
3-year warranty
