Connect your DVI Dual Link display to a DisplayPort video source, for high resolution applications. The DP2DVID2 DisplayPort to DVI (Dual-Link) Adapter actively converts the output signal from a DisplayPort video source for use with a DVI-D display (monitor, etc.) or projector, helping to eliminate the equipment costs of upgrading a DVI display to a newer model for the sake of compatibility.
The adapter supports high resolution video (up to 2560x1600), maintaining the outstanding graphical performance from a DisplayPort-equipped desktop video card, laptop or MacBook.
DP2DVID2 performs an active DisplayPort-DVI conversion that is suitable for video sources that output either multimode (DP++) or single-mode DisplayPort signals. This ensures the adapter can be used even with graphics cards that aren't capable of outputting multimode DP++ signals, such as ATI Eyefinity cards.
- StarTech.com DisplayPort to DVI Adapter – Dual-Link – Active DVI-D Adapter for Your Monitor / Display - USB Powered – 2560x1600 (DP2DVID2) - video converter - black
- Video converter
- Max Resolution
- 2560 x 1600
- 1 x DisplayPort input - 20 pin DisplayPort , 1 x DVI-D output - 24+1 pin digital DVI , 1 x USB - 4 pin USB Type A
- 10.55 cm x 8.8 cm x 2.2 cm
- Enclosure Colour
- Black
- 3-year warranty
- Video converter
- Max Resolution
- 2560 x 1600
- 1 x DisplayPort input - 20 pin DisplayPort - male , 1 x DVI-D output - 24+1 pin digital DVI - female , 1 x USB - 4 pin USB Type A - male
- USB powered
- FCC, RoHS
- 10.55 cm
- 8.8 cm
- 2.2 cm
- 175 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 45 °C
StarTech.com 6 ft DVI-D Dual Link Cable - M/M | In Stock | £6.62 |
StarTech.com 10 ft DVI-D Dual Link Cable - M/M | In Stock | £10.60 |
StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F | In Stock | £3.59 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £10.00 |
StarTech.com DisplayPort DVI Video Adapter Converter | In Stock | £13.56 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £10.10 |
StarTech.com 6 ft DisplayPort to DVI Cable - M/M | In Stock | £15.38 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £18.34 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £21.76 |
StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 | In Stock | £94.42 |
StarTech.com 3ft DP to DVI Converter Cable | In Stock | £15.28 |
