StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600
Quicklinx: 8G54WS00 Mfr#: DP2DVID2
More than 50 in stock
£95.60 ex VAT
£114.72 inc VAT
Connect your DVI Dual Link display to a DisplayPort video source, for high resolution applications. The DP2DVID2 DisplayPort to DVI (Dual-Link) Adapter actively converts the output signal from a DisplayPort video source for use with a DVI-D display (monitor, etc.) or projector, helping to eliminate the equipment costs of upgrading a DVI display to a newer model for the sake of compatibility.
The adapter supports high resolution video (up to 2560x1600), maintaining the outstanding graphical performance from a DisplayPort-equipped desktop video card, laptop or MacBook.
DP2DVID2 performs an active DisplayPort-DVI conversion that is suitable for video sources that output either multimode (DP++) or single-mode DisplayPort signals. This ensures the adapter can be used even with graphics cards that aren't capable of outputting multimode DP++ signals, such as ATI Eyefinity cards.
StarTech.com DisplayPort to DVI Adapter – Dual-Link – Active DVI-D Adapter for Your Monitor / Display - USB Powered – 2560x1600 (DP2DVID2) - video converter - black
Video converter
Max Resolution
2560 x 1600
1 x DisplayPort input - 20 pin DisplayPort , 1 x DVI-D output - 24+1 pin digital DVI , 1 x USB - 4 pin USB Type A
10.55 cm x 8.8 cm x 2.2 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
2560 x 1600
1 x DisplayPort input - 20 pin DisplayPort - male , 1 x DVI-D output - 24+1 pin digital DVI - female , 1 x USB - 4 pin USB Type A - male
USB powered
FCC, RoHS
10.55 cm
8.8 cm
2.2 cm
175 g
Enclosure Colour
Limited warranty - 3 years
45 °C
8G54 StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.71
8G54 StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.72
8G54 StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F In Stock £3.54
8G54 StarTech.com DisplayPort DVI Video Adapter Converter In Stock £13.69
8G54 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.18
8G54 StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £15.53
8G54 StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £18.55
8G54 StarTech.com DisplayPort to DVI Active Adapter In Stock £22.04
8G54 StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £95.60
8G54 StarTech.com 3ft DP to DVI Converter Cable In Stock £15.43
Price Range Ex VAT: 50 - 100
