StarTech.com DisplayPort to DVI Active Adapter
Quicklinx: 7NXJWS00 Mfr#: DP2DVIS
Length: 20cm
19 In Stock
£21.58 ex VAT
£25.89 inc VAT
The DP2DVIS DisplayPort to DVI Active Single Link adapter lets you connect your DisplayPort video source (desktop PC, laptop, etc.) to a DVI-D monitor, projector or display, including televisions and Apple Cinema Display HD, eliminating the expense of having to upgrade to a DisplayPort-capable monitor. Unlike passive adapters, this DP to DVI converter offers an active conversion for use with any DisplayPort output - ideal for graphics cards that are not capable of outputting multi-mode DP++ signals (e.g. ATI Eyefinity). Supporting resolutions up to 1920x1200, this compact device provides a simple solution for converting DisplayPort output for compatibility with existing DVI monitors, televisions or projectors.
  • Versatile connectivity
    This adapter converts signals from DisplayPort to DVI, allowing for a wide range of display options. Users can connect laptops, desktops, and other devices to DVI-based displays.
  • High-resolution support
    Capable of delivering resolutions up to 1920 x 1200, this adapter ensures that users enjoy clear and crisp image quality, ideal for both work and entertainment.
  • Secure digital transmission
    With HDCP compliance, this adapter ensures the secure transmission of protected content, making it suitable for streaming high-definition media without interruptions.
  • Compliance with standards
    The adapter meets FCC and RoHS standards, reflecting its reliability and adherence to safety guidelines in electronic devices.
StarTech.com DisplayPort to DVI Adapter - Active Conversion - 1920x1200 - DP to DVI Single Link Converter for DVI-D Display (DP2DVIS) - DisplayPort adapter - 20 cm
DisplayPort adapter
HDCP compliant
Length
20 cm
Connector
DisplayPort - male
Connector (Second End)
DVI-D - female
FCC, RoHS
3-year warranty
P/N: DK30C2DAGPD, DKM30CHDPD, DKM30CHDPDUE, DKWG30DPHPD, DKWG30DPHPDU, MST30C2DPPD, SP123DP, SV231QDPU34K, TB32DP14, TB32DP2T, TB3CDK2DP, TB3CDK2DPUE, TB3CDOCKDP, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, TB3DKM2DP, TB3DKM2DPL
DisplayPort adapter
HDCP compliant
Length
20 cm
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - female
DisplayPort 1.1a, FCC, RoHS
3-year warranty
7NXJ StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £8.55
7NXJ StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.26
7NXJ StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £21.83
7NXJ StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.05
7NXJ StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £5.73
7NXJ StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.18
7NXJ StarTech.com DisplayPort to DVI Active Adapter In Stock £21.58
7NXJ StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £40.38
7NXJ StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £18.38
7NXJ StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £30.81
7NXJ StarTech.com 3ft DP to DVI Converter Cable In Stock £14.34
Length: 20cm
