Connect your DVI monitor to a DisplayPort equipped computer. The StarTech.com DP2DVIADAP DisplayPort DVI adapter lets you connect a DVI-D display to a DisplayPort video source (e.g. DisplayPort video cards, etc.), eliminating the expense of having to upgrade to a DisplayPort enabled display while providing a hassle-free connection to any DisplayPort video card/signal source.
The DVI/DisplayPort adapter supports display resolutions up to 1920x1200, allowing you to take full advantage of single link DVI capability.
DP2DVIADAP is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
- StarTech.com DisplayPort DVI Video Adapter Converter - DisplayPort to DVI Converter - DP to DVI - DisplayPort to DVI Adapter (DP2DVIADAP) - DisplayPort adapter
- DisplayPort adapter - single link
- Connector
- DisplayPort - male
- Connector (Second End)
- DVI-D - female
- FCC, RoHS
- 3-year warranty
- Designed For
- P/N: DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M
- TMDS Links
- Single link
- Connector
- 20 pin DisplayPort - male
- 24+1 pin digital DVI - female
- FCC, RoHS
- 3-year warranty
- Designed For
StarTech.com 6 ft DVI-D Single Link Cable - M/M | In Stock | £6.85 |
StarTech.com 15 ft DVI-D Single Link Cable - M/M | In Stock | £13.69 |
StarTech.com 6 ft DVI-D Dual Link Cable - M/M | In Stock | £8.14 |
StarTech.com 10 ft DVI-D Dual Link Cable - M/M | In Stock | £10.71 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £15.63 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £15.04 |
StarTech.com DisplayPort DVI Video Adapter Converter | In Stock | £13.67 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £33.35 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £26.98 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £22.36 |
StarTech.com 10 ft DVI-D Single Link Cable - M/M | In Stock | £8.09 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £18.52 |
