StarTech.com Desktop Monitor Stand with Cable Hook - Mounting Kit
Quicklinx: B6XVWS00 Mfr#: ARMPIVSTND
Accessory Type: Stand
£73.95 ex VAT
£88.74 inc VAT
Place a display, up to 30" in size, at your desk, using this height-adjustable monitor mount with integrated cable management. The adjustable monitor stand lets you mount a display on your desk, with tilt, pivot and height adjustments for perfect positioning. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The monitor stand holds most common displays with ease, supporting monitors from 12 - 30" up to a maximum weight capacity of 30lbs (14kg). For added flexibility, the included hardware can be used to mount your Apple iMac or Apple Cinema Display.
The desktop monitor stand features a 15in (380mm) tall support post, for a much greater range of height adjustments than typical monitor stands can provide. For viewing longer pages or blocks of code without scrolling, the LCD stand also supports landscape to portrait display rotation.
Adjust your display height, position and viewing angles easily to create an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk by mounting on a support post above the desk surface.
StarTech.com Single Monitor Stand - Adjustable - Supports Monitors 12" to 34" - Premium - Single Screen VESA Monitor Mount Stand - Silver (ARMPIVSTND) - mounting kit
Mounting kit
Mounting Components
Desk stand, feet, wrench, screws, cable clip
Adjustments
Pan, tilt
3.3 kg
Recommended Use
LCD display
Recommended Display Size
12"-30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
14 kg
Material
Plastic, steel
Silver
5-year warranty
3.3 kg
Material
Plastic, steel
Silver
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Cable Management
Integrated cable management
12"-30"
Adjustments
Pan, tilt
Max Load Weight
14 kg
Adjustable height, portrait to landscape movement, swivel adjustment, pivot
Limited warranty - 5 years
B6XV StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £68.32
B6XV StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount In Stock £64.91
B6XV StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable Hook In Stock £56.15
B6XV StarTech.com Articulating Monitor Arm In Stock £103.13
B6XV StarTech.com DVI Laptop Docking Station In Stock £67.27
B6XV StarTech.com 4K DP Laptop Docking Station In Stock £100.60
B6XV StarTech.com USB-C Multifunction Adapter 4K In Stock £47.58
B6XV StarTech.com USB-C Multifunction Adapter In Stock £61.41
Price Range Ex VAT: 50 - 100
